Page 1 sur 4 1234 DernièreDernière
Affichage des résultats 1 à 45 sur 163
    Par défaut Belle annonce Tamron ...
    Annonce du jour, le remplaçant du 28-75 ! Stabilisé, motorisation rapide et silencieuse et de jolie morceaux de verre dedans ...
    Tamron SP 24-70mm f/2.8 Di VC USD
    Product Features
    1. A full-size, high-speed standard zoom with built-in VC ( Vibration Compensation). Even when shooting in low-light conditions with a slow shutter speed to render sharpness, Tamron’s acclaimed VC allows for stable handheld camera work, to more fully enjoy the benefits of this high-speed zoom lens.
    2. Uses special high-grade glass in the three LD elements, three glass molded aspherical lenses, one hybrid aspherical lens and two XR (Extra Refractive Index) glasses, delivering top-of-the-class quality images suited to this high-grade lens. Using a rounded diaphragm, the lens achieves gorgeous blur effects. This rounded diaphragm retains a nearly circular shape even when taken two stops down from its fully open state.
    3. Features Tamron proprietary USD ( Ultrasonic Silent Drive) to power a speedy AF drive together with a continuous manual mechanism.
    4. This high-speed standard zoom lens has a wide-end focal length of 24mm that expands the photographic area.
    5. The lens adopts the new technology including the latest optical design, VC ( Vibration Compensation) image stabilization and USD ( Ultrasonic Silent Drive), all in a lighter and more compact package.
    6. Moisture-resistant construction helps prevent water from penetrating the lens.
    Specifications:
    Model: A007
    Focal length: 24-70mm
    Maximum aperture: F/2.8
    Angle of view (diagonal): 84°04’ -34°21’ (for full frame 35mm format cameras)
    60°20’ -22°33’ (for APS-C format cameras)
    Lens construction: 17 elements in 12 groups
    Minimum focus distance: 0.38m (15.0 in)
    Maximum magnification ratio: 1:5 (at f=70mm: MFD 0.38m)
    Filter size: φ82mm
    Length: 108.5mm*
    Entire Length: 116.9mm*
    Diameter: φ88.2mm
    Weight: 825g*
    No. of diaphragm blades: 9 (rounded diaphragm)
    Minimum aperture: F/22
    Standard accessories: Flower-shaped lens hood
    Compatible mounts: Canon, Nikon, Sony
    Membre Avatar de Picasso67
    Ile de France
    EOS 550D; Canonet QL 17 GIII, EOS 5
    Canon : 18-55 IS | 55-250 IS | 50 f/1.8 II | 28 2.8 | 40 1.7 | Tamron 28-75 2.8
    ça va faire mal
    Déjà que la qualité du 28-75 non stabilisé était terrible vs son prix... là il va falloir réfléchir beaucoup avant d'acheter le Canon non stabilisé.
    J'attends les tests avec impatience
    Ouais vite les tests Perso je suis déjà tenté faut dire pour remplacer le 28-75 que j'ai déjà . Si il est encore meilleur optiquement et avec sa maj de motorisation ca risque de faire mal !
    Abonné Avatar de rem22
    5D mark II - 430ex2
    moi qui n'arrivais pas à trancher 24-70L 24-105L 28-75.....purée je vais attendre les tests, mais c'est une super news ça Fredo !
    F/2.8, stabilisé....yippikai !
    Membre Avatar de niwen
    mordor
    6D + Rollei F 2.8
    Canon : 16-35 LII ; 70-200/4 IS ; Tamy : 24-70/2.8 VC
    Serait-ce l'équivalent du 17-55 que j'attendais depuis longtemps pour passer au FF ? Vivement les tests.
    Merci pour l'annonce
    Non c'est pas l'équivalent du 17-55 VC : Celui la a une motorisation USD ! L'équivalent USM de chez Tamron ...
    5D mark II - 430ex2
    Fredo, je pense qu'il voulait plutot dire qu'il attendait pour passer au FF un équivalent du 17-55 sur aps-c : f/2.8, stabilisé. Et bonne qualité optique.
    Ayant eu le 17-55, puis étant passé au FF, je comprends pleinement la remarque puisque je partage le "creux" en FF coté transtandard.
    Le 17-55, bien que boudé par un certain nombre, est vraiment l'objectif parfait pour aps-c, alors qu'en FF....faut faire des compromis, sur des objectifs plus chers en plus, que le 17-55.
    Pour le 17-55, j'avais été mis en garde par Canon-Passion, qui avait bien raison.
    J4adore mon FF, mais coté transtandard j'étais un peu frustré, ce tamy va ptet changer la donne. 82mm en filtre par contre ça fait ch***
    Le poids aussi 825g ... M'enfin moins lourd que le Canon 24-70 L (950g). Vrai que 82mm ca va faire cher le pola (77mm le canon)
    Membre Avatar de Ayrton93
    février 2011
    Centre
    60D // 1D Mk IV
    Super nouvelle
    Dia 82 mm quand même
    Il y a beaucoup de changement à l'intérieur de ce fait ...
    mordor
    6D + Rollei F 2.8
    Je parlais du Canon 17-55 2.8. Ce qui me chagrinait pour passer au FF c'est de ne pas trouver un équivalent, le Canon 24-70 n'étant pas stabiliisé. Certains diront que la stab n'est pas nécessaire pour ce type de range mais pour mon usage elle est pratiquement indispensable
    edit : Rem22 a très bien exprimé ce que je voulais dire
    Dernière modification par niwen ; 06/02/2012 à 12h42.
    A priori c'est une nouvelle version de la stabilisation Tamron aussi ... Vraiment un objectif 100% nouveau ! Vivement les tests !
    5D mark II - 430ex2
    82->77mm si on est à f/8 ou f/11 ça devrait le faire avec une bague à 5€ sur la bay je pense.
    Ouais mais perso j'ai rien en 82 Alors que du 77mm oui Ca me fait encore un pola de plus ...
    fuji x100T, fuji X-T1
    fuji 10-24 f/4, fuji 56 f1,2
    Tamron coupe l'herbe sous les pieds de Canon avant même la sortie de leur nouveau 24-70L...
    Remarque, à force de faire des effets d'annonces chez Canon, ça va leur faire les pieds
    Membre Avatar de Max160
    février 2010
    Tours
    1Dx, 1DsII, 10D
    Et puis une fois que tu auras un filtre 82 mm, peut-être seras-tu tenté d'acheter un UGA sur lequel l'utiliser (pas très bon pour le porte-feuille par contre) : 18/21 Zeiss, 16-35 II Canon, 17-35 f/4 Tokina...
    Abonné Avatar de Kinggarden
    Territoire de Belfort
    Canon - Tamron
    Rien qu'à voir la photo cet objectif inspire confiance! Tamron et Sigma font maintenant de gros efforts qualitatifs, tout laisse penser que ce 24-70/2.8 VC USD sera bon, voire très bon, à un prix abordable si il suit le chemin de ses prédécesseurs. Mas bien sûr, attendons d'en savoir plus...
    Membre Avatar de Vynz100
    juillet 2010
    Centre France
    5D Mark II - R6
    Intéressant pour les voyages par exemple...
    Membre Avatar de Nykos
    septembre 2011
    Val d'Europe (77)
    de plus en plus open...
    Miam !
    Vu comment le 28-75 m'a servi de bouchon sur le 300D (et continue sur le 600D de madame), je vais attendre avec impatience de voir ce que ce 24-70 peut donner en stabilisé et avec un AF plus rapide. !
    Merci Tamron !
    Membre Avatar de didou47
    Niort (79)
    450D, 7D
    100mm macro + 24-105 L IS + 70-300 L +50 1,4 + 135 L (et maintenant j'arrête!)
    on peut avoir une idée d'estimation de son prix ou pas encore?
    Membre Avatar de Bargaz
    Metz France
    EOS 5DIII - S100
    17-40 F4 - Tam 24-70VC - 70-200 F4 IS - Sig 50 F1,4 - 40 STM
    Pas sure qu'il reste aussi "bon marché" que l'ancienne version !
    Non y'a pas d'indication de prix donné. Moins que les 1200 € du L et plus que les 350 € du 28-75 ... Moi je le sentirais bien dans les 800 ...
    Canon - Tamron
    Citation Envoyé par Bargaz Voir le message
    Il sera plus cher, ça c'est sûr, mais de combien ?
    Nancy
    40D / 6D / G12 / NEX5
    17-40 f4 L / 24-105 IS f4 L / 70-200 IS f4 L / 100 f2.8 USM macro
    Si il sort dans les 800euros, c'est avec le 24-105L que le combat aura lieu !
    Non ca sera pas un combat 24-70 USD 24-105 L. Le 24-105 L a pour lui son range qui est très confortable a l'usage. Pour moi y'a jamais eu dilem entre un 24-70 a 2.8 et le 24-105 L. J'ai pour l'instant un 28-75 et le 24-105 L et les 2 ont leur utilisation en fait ... Le premier qui sort un 24-105 a 2.8 Stabilisé par contre et a moins de 1.4 Kg et 1500 € par contre je signe
    Du très très lourd cette annonce, à part les 82mm
    Membre Avatar de mouzhik
    M2 + M6
    +1
    moi aussi je signe tout de suite... mais il faut pas rêver, ça serait plutôt dans vers 1,6 Kg minimum et 2000€...
    juillet 2010
    Centre France
    5D Mark II - R6
    Citation Envoyé par willz Voir le message
    Ah non, enfin une taille compatible avec le Zeiss 21mm! Je pourrai justifier mon achat de filtre du coup...
    Citation Envoyé par Vynz100 Voir le message
    Toi oui, pas moi..
    Sinon il est aussi à noter côté esthétique (et prise en main) que la largeur des dexu bagues (focale et focus) a été inversé, celle de focale est devenu plutôt mince et celle de focus bien plus large
    Non je crois que le focus est la petite bague et la focale la grosse. Le trait blanc est fixe, et les chiffres bougent avec la bague AMHA.
    Abonné Avatar de Pixels d'Argent
    novembre 2011
    EF
    Excellente nouvelle, Tamron grille la politesse à Canon, déjà en le sortant un peu en avance, d'autre part avec la stabilisation car il s'avèrerait hélas que le Canon ne serait pas stabilisé.
    Dernière modification par Pixels d'Argent ; 06/02/2012 à 16h09.
    Yes bien vu
    Donc ils ont carrément inversé les deux bagues (celle de focus est au plus près de la lentille sur le 28-75), ce qui est beaucoup plus pratique à l'usage amha.
  32. #32
    septembre 2010
    5D Mark III
    16-35 f4 L IS / 24L II / 85mm 1.4 / 70-200 2.8 L IS II / doubleur V2
    Le 24/70 LII "aurait" un prix tournant autour de 1800$, sans IS... ça fait du tamron un sacré concurrent.
  33. #33
    Membre Avatar de davidemb
    EOS 30, 430 EX II, 6D
    135L, 100L, 24-105L, 85 F1.8 et sigma 35 F1.4 (et 17-40 malade car grosse chute...)
    ah, on verra les tests mais il se pourrait bien que beaucoup de 28-75 soient dans les PA...Le mien y sera certainement si le prix de ce beau joujou reste raisonnable
  34. #34
    EOS 450 D
    sports
    Moteur annulaire ou pas?
  35. #35
  36. #36
    Membre Avatar de Desp
    mai 2010
    5D Mark III
    EF 24-105mm f/4L IS USM + EF 50 mm f/1.8
    Dommage que ce ne soit pas un 24-70 pour ASP-C :-D
    Il me tenait bien aussi, mais ducoup sur mon 550D je pense que je vais prendre le 17-55…
  37. #37
    tarn
    1DII
    En reconstruction !!
    En concurrent il a aussi en face de lui le sigma 24/70 f2.8 ex dg hsm dans les 850€ avec deja des filtres en 82 et un poids presque identique dans les 900grs.
    Perso j'ai prefere le sigma au canon qu'en je suis passé au FF apres avoirs vus les differents problemes d'ajustement des lentilles à PO du canon.
  38. #38
    Niort (79)
    450D, 7D
    personnellement, je pense que ça sera mon premier objectif non Canon! Il me plaît bien et à un tarif raisonnable a priori, surtout quand on voit le nouveau 24-70 Canon!
  39. #39
    5D mark II - 430ex2
    Regarde les différents tests du sigma 24-70....Il semble pas très bon à f/2.8, plutot à considérer comme un 24-70 f/4, pour un prix assez elevé je trouve.
    J'espère que le tamron fera mieux que le sigma de ce coté là....mais j'ai plus confiance en tamron qu'en sigma.
  40. #40
    IDF, France
    400D, 7DII, 5DII
    10 / 22, 17 / 55 IS, 24 F2.8 IS, 50 F1.4, 85 F1.8, 135 F2L
    Clair qu'avec la stab, vu le prix annoncé du nouveau 24-70 Canon, ça va faire un carton !
    Attendons les tests mais je m' en fais pas pour Tamron, ils savent très bien se placer en qualité/prix même si là, l' équipement est au niveau des meilleurs.
    Dernière modification par elnunu ; 07/02/2012 à 10h36.
  41. #41
    EOS 450 D
    sports
    On verra bien ce que vaut son autofocus.
  42. #42
    M2 + M6
    Citation Envoyé par elnunu Voir le message
    à quel prix est annoncé le nouveau 27-70mm Canon?
  43. #43
    Niort (79)
    450D, 7D
    Citation Envoyé par mouzhik Voir le message
    pas d'annonce officielle apparemment mais à plus de 2500 euros.
  44. #44
    EOS R5, EOS R, 7D mk 2/ 40D/ g7x
    RF 24-105Lf4is/ efs17-55F2.8 ISUSM/ 70-200F2.8 L 2 ISUSM/100F2.8macro/15-85/18-200IS
    A quel prix est-il annoncé? Vu le nouveau Canon 24-70 f2.8 L II sans IS, celui-ce me botte beaucoup plus. Je ne sais pas ce que vaut le VC Tamron comparé à l'IS, mais il a au moins le mérite d'être présent!
  45. #45
    Membre Avatar de Bricou51
    Marne
    7D - 400D
    [17-55 2,8 IS USM][70-200 F4L][100 Macro 2.8 USM][TC1.4][430EXII][YN560II]
    Seul bémol, le fut qui s'allonge quand on zoom puisqu'il y a le petit bouton "Lock".
  1. Annonce Tamron 70-300 DI VC USD
    Par Fredo_45 dans le forum Discussions Objectifs
    Réponses: 31
    Dernier message: 23/06/2010, 22h59
  2. Belle belle belle comme le jour
    Par Balilaï dans le forum [Noir & Blanc]
    Dernier message: 30/05/2009, 18h27
  3. Tamron AF17-50mm 2.8 ou Tamron AF28-75mm 2.8 ?
    Par Dexter971 dans le forum Discussions Objectifs
    Dernier message: 20/04/2009, 11h25
  4. Annonce Tamron SP AF60mm F/2.0 Di II MACRO 1:1
    Dernier message: 24/03/2009, 12h35
  5. Réponses: 2
    Dernier message: 31/03/2006, 18h24
Fuseau horaire GMT +1. Il est actuellement 10h38.
