Citation:
1D Mark V
It’s rare to see a spec list such as the one below. It goes down the same path as most information coming in. The 1D & 1Ds will be merged into the 1D Mark V. The 1Ds will be replaced by a more studio oriented camera and called something else.
Specs of the 1D MK V
Image ratio w:h 3:2
Effective pixels 32,2 megapixels
Sensor photo detectors 32.5 megapixels
Sensor size Full frame (36 x 24 mm)
Sensor type CMOS
Processor Digic 5
ISO 100, 200, 400, 800, 1600, 3200, 6400, 12800 (50, 25600, 51200 and 102400 Hi)
White balance presets 8
Custom white balance Yes
Image stabilization No
Uncompressed format RAW JPEG quality levels Fine,
Normal (can have ratios programmed)
Autofocus Contrast Detect (sensor), Phase Detect, Multi-area, Selective single-point, Single, Continuous, Face Detection, Live View
Digital zoom No
Manual focus Yes
Number of focus points 45
Lens mount Canon EF mount
Focal length multiplier 1.0×
Articulated LCD Fixed
Screen size 3.2″
Screen dots 1.200,000
Touch screen No Live view Yes
Viewfinder type Optical (pentaprism)
Viewfinder coverage 100 %
Viewfinder magnification 0.76×
Minimum shutter speed 30 sec
Maximum shutter speed 1/8000 sec
Aperture priority Yes
Shutter priority Yes
Manual exposure mode Yes
Subject / scene modes No
Built-in flash No
External flash Yes (Hot-shoe plus Sync connector)
Flash modes External / Radio Controlled
Continuous drive Yes (9.1 fps)
Self-timer Yes (2 or 10 sec)
Metering modes Multi Center-weighted, Spot
Exposure compensation ±3 EV (at 1/3 EV, 1/2 EV steps)
AE Bracketing ±3 (3 frames at 1/3 EV, 1/2 EV steps)
WB Bracketing Yes (3 frames in either blue/amber or magenta/green axis)
Format H.264
Audio channels Stereo
Clips Yes (1920 x 1080 (120, 60, 30, 25, 24 fps, 1280 x 720 (120, 60, 50 fps), 640 x 480 (120, 60, 50 fps))
HD Modes 1920 x 1080 (120, 60, 30, 25, 24 fps, 1280 x 720 (120, 60, 50 fps), 640 x 480 (120, 60, 50 fps) FPS 1920 x 1080 (120, 60, 30, 25, 24 fps, 1280 x 720 (120, 60, 50 fps), 640 x 480 (120, 60, 50 fps)
Storage types Compact Flash (Type I or II), UDMA, SD/SDHC card
Storage included None
USB USB 3.0
HDMI Yes
Remote control Yes (N3 connector)
Environmentally sealed Yes
Battery Battery Pack
Battery description Lithium-Ion LP-E4 rechargeable battery & charger
Battery Life (CIPA) 1500
Weight (inc. batteries) 1228 g
Dimensions 157 x 159 x 80 mm
Orientation sensor Yes
Timelapse recording Yes (by cable and PC)
Vala pour la tartine du jour. J'ai mis de la sauce tomate sur certains points ''intéressants''. Bonne digestion. Sur le papier ça donne faim. reste à savoir.... enfin comme d'hab. S'ils prévoient un modèle studio en marge du 1DV qui serait alors l'outil de terrain, ceci voudrait-il dire que le positionnement tarifaire du 1DV serait celui d'un 1DIV (donc APSH de today)? Ca pourrait être sympathoche. Qui vivra verra.
