Affichage des résultats 1 à 45 sur 194
Discussion: taille capteur FF et Aps-c, les effets
10/05/2016, 09h40 #1Membre
- juillet 2010
- Bruxelles
- 71
- 4 799
- Eos 7D - 100D
Non.
Le jpeg n'est pas nécessairement destructeur. Selon les programmes la compression va de 1 à 10 ou de 1 à 12, le chiffre le plus grand est sans destruction de données.
Désolé pour le texte jaune, c'est pour distinguer les sources.
Pas de soucis ca aide a la lisibilite du texte ;-)
Voici ce que dit le site Canon:
Lossless and lossy compression/Canon RAW format
File compression techniques that lose some of the original data are called ‘lossy’. However, ‘lossless’ compression is also available. This is used by Canon digital cameras when the highest resolution image is stored as RAW data.
Lossless compression uses mathematical algorithms to pack all the data into less space. This compression is fully reversible, so that when the file is opened, all the data is still there. This means that there is no reduction in image quality.
Lossless compression cannot achieve the file size reductions offered by JPEG compression, but Canon RAW format files can often be saved at a quarter of the size of an uncompressed file. (The actual file size is affected by the subject and the ISO speed.)
The RAW setting captures all the sensor data and records it without any significant processing inside the camera. This means that you can work on the file once it has been downloaded to a computer, experimenting with different settings until you get the image you want. This extends to adjusting the colour balance and other image parameters such as sharpness and contrast.
A RAW file is often described as a ‘digital negative’, because it offers the creativity given by a film negative in the darkroom.
Voici le détail du code RAW: on remarquera que la mention jpeg y figure à plusieurs endroits. Si on suit le lien en orange, un autre détail est accessible, qui mentionne lui aussi la présence de compression jpeg sans perte dans le RAW.
Code: [Select]
Although not publicly documented by Canon, their CR2 RAW file format specifiction is scattered in bits and pieces across the web. Compiled here is believed to be an accurate specification for the orignal CR2 compression. Because I own the original Canon 5D, this specification reflects its CR2 formatting. Newer 5D versions have other compression varieties such as sRAW (sRAW1, sRAW2, etc.), and these are not supported by this software.
Included here is the CR2 coder/decoder and a zip file of its C-code implementation. The companion Canon CRW Specification may also be of interest. Another good source of CR2 information can be found in a document titled Understanding What is stored in a Canon RAW .CR2 file, How and Why at Inside the Canon RAW format version 2, understanding .CR2 file format and files produced by Canon EOS Digital Camera.
The specifiction is listed below and is included in the cr2.zip (revised 11/10/08) file as comments of the primary code file Cr2Codec.cpp. The zip file contains the following:
Cr2Codec.cpp - Primary C-code for CR2 coder/decoder
Cr2Codec.exe - its sample excutable
Cr2Codec.h - its header file
MakerNote.h - A few definitions for Canon's TIFF maker-note
Prop.h - Properties type definitions
RawUtl.cpp - Various raw utilities
RawUtl.h - and its header file
TiffTags.h - TIFF tag definitions
TiffUtl.cpp - Various TIFF utilities
TiffUtl.h - and its header file
getput.cpp - Low level input/output
getput.h - and its header file
jpeg.h - Various JPEG definitions
The executable Cr2Codec.exe must be run in a Windows command shell. Executing the command without parameters yields its syntax as follows:
Usage: Cr2Codec.exe [options] file.cr2 outfile
Decompress raw image data of file.cr2
-b: decode then save binary file (default)
-c: decode then recode file
-h: decode then create (text) histogram
-j: extract JPG image
-t: decode then save as 8-bit TIFF file
-T: decode then save as 16-bit TIFF file
Version 1.0
Wildtramper.com, Copyright (c), All rights reserved
Although the -t or -T options create a TIFF file from RAW, expect crude colorization. The -j option is useful to extract the embedded JPG file, and it has Canon's as-shot colorization. This JPG is believed to be optimized for the camera's on-board LCD display -- what to heck, it's a quick view.
* The Canon CR2 file format is an encapsulated TIFF shell having 4 IFD sets.
* These IFDs are different versions of the same image.
* +=====================================+ Start of TIFF/CR2 file
* | TIFF Header |
* | Size = 8 |
* | Various TIFF Tags describing File | IFD #1 Segment
* | EXIF (TIFF subdirectory) | Canon 5D image size 2496x1664
* | JPEG data (baseline compression) |
* | JpegInterchangeFormat | IFD #2 Segment
* | | unknown image size
* | JPEG Compressed data |
* | Few TIFF Tags describing segment | IFD #3 Segment
* | | Canon 5D image size 384x256
* | JPEG data (unknown compression) |
* | Few TIFF Tags describing segment | IFD #4 Segment - RAW image
* | | Canon 5D image size 4476x2954
* | JPEG data (lossless compression) |
* A sample parsing of these IFDs are:
* sample.cr2: FileID=II, Ver=2A, IFD #1 w/ 14 Tags
* TagName(TagID,Len,DataOfst) =Value
* ImageWidth(0100,1,001A) =2496
* ImageLength(0101,1,0026) =1664
* BitsPerSample(0102,3,00BE) =8 8 8
* Compression(0103,1,003E) =6 {JpegCompression}
* Make(010F,6,00C4) ="Canon"
* Model(0110,D,00CA) ="Canon EOS 5D"
* StripOffsets(0111,1,0062) =82349
* Orientation(0112,1,006E) =1 {TopLeft, Normal}
* StripByteCounts(0117,1,007A)=1030590
* XResolution(011A,1,00EA) =72/1 (=72)
* YResolution(011B,1,00F2) =72/1 (=72)
* ResolutionUnit(0128,1,009E) =2 {InchUnits}
* DateTime(0132,14,00FA) ="2006:09:24 07:14:52"
* Exif(8769,1,00B6) =270
* ExposureTime(829A,1,0264) =1/80 (=0.0125)
* FNumber(829D,1,026C) =4/1 (=4)
* ExposureProgram(8822,1,0130) =3
* ISOSpeedRatings(8827,1,013C) =100
* ExifVersion(9000,4,0148) =48 50 50 49
* DateTimeOriginal(9003,14,0274) ="2006:09:24 07:14:52"
* DateTimeDigitized(9004,14,0288) ="2006:09:24 07:14:52"
* ComponentsConfiguration(9101,4,016C) =1 2 3 0
* ShutterSpeedValue(9201,1,029C) =417792/65536 (=6.375)
* ApertureValue(9202,1,02A4) =262144/65536 (=4)
* ExposureBiasValue(9204,1,02AC) =0/1 (=0)
* MeteringMode(9207,1,019C) =5
* Flash(9209,1,01A8) =16
* FocalLength(920A,1,02B4) =24/1 (=24)
* MakerNote(927C,12548,02BC) =29 0 1 0 3 0 46 0 0 0 30 4 0 0 2 ...
* UserComment(9286,108,12804) =0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ...
* FlashpixVersion(A000,4,01D8) =48 49 48 48
* ColorSpace(A001,1,01E4) =1
* PixelXDimension(A002,1,01F0) =4368
* PixelYDimension(A003,1,01FC) =2912
* Interoperability(A005,1,0208) =76044
* FocalPlaneXResolution(A20E,1,1292A) =4368000/1415 (=3086.93)
* FocalPlaneYResolution(A20F,1,12932) =2912000/942 (=3091.3)
* FocalPlaneResolutionUnit(A210,1,022C)=2 {InchUnits}
* CustomRendered(A401,1,0238) =0
* ExposureMode(A402,1,0244) =0
* WhiteBalance(A403,1,0250) =0
* SceneCaptureType(A406,1,025C) =0
* sample.cr2: FileID=II, Ver=2A, IFD #2 w/ 2 Tags
* JPEGInterchangeFmt(0201,1,12944) =76348
* JPEGInterchangeFmtLen(0202,1,12950)=6001
* sample.cr2: FileID=II, Ver=2A, IFD #3 w/ 11 Tags
* ImageWidth(0100,1,12962) =384
* ImageLength(0101,1,1296E) =256
* BitsPerSample(0102,3,129E2) =8 8 8
* Compression(0103,1,12986) =6 {JpegCompression}
* Photometric(0106,1,12992) =2 {RGB}
* StripOffsets(0111,1,1299E) =1112939
* SamplesPerPixel(0115,1,129AA)=3
* RowsPerStrip(0116,1,129B6) =256
* StripByteCounts(0117,1,129C2)=294912
* PlanarConfig(011C,1,129CE) =1 {ChunkyFormat}
* UndefinedTag(C5D9,1,129DA) =2
* sample.cr2: FileID=II, Ver=2A, IFD #4 w/ 6 Tags
* Compression(0103,1,129F2) =6 {JpegCompression}
* StripOffsets(0111,1,129FE) =1407851
* StripByteCounts(0117,1,12A0A)=9920742
* UndefinedTag(C5D8,1,12A16) =1
* UndefinedTag(C5E0,1,12A22) =1
* UndefinedTag(C640,3,12A36) =1 2238 2238
* The first IFD is a low pixel count JPEG image, and for the Canon 5D its image
* size is 2496x1664. Also included as part of the first IFD are an assortment
* of image and shot data, such as Make, Model, and abundant EXIF information.
* The EXIF information is itself an IFD subdirectory, and within the EXIF
* directory is the Tag 'MakerNote' which contains more shot information such a
* lens type and serial numbers. MakerNote is has a TIFF like IFD structure,
* but the "TagType" field follows different rules, see below.
* The second IFD is another JPEG rendered image, and it is described by two
* TIFF Tags. It is not clear what the purpose of this image, but noting that
* the section size is very small (6001 bytes in the sample), then the image
* dimensions must also be small. It is likely a thumbnail. Peeking into this
* section one finds four JPEG markers: SOI (start of image), DHT (define
* Huffmann tables), DQT (define quantization tables), and SOS (start of scan).
* There is no SOFn marker to identify the image dimensions.
* The third IFD is another JPEG rendered image. In this case there are several
* TIFF tags, and these give the size of the image as 384x256. Certainly a
* small image. Although the compression is tagged as JPEG, it is believed this
* is not the case since (1) the image data contains no JPEG markers and (2) the
* size of the image data is exactly three times the rows times columns (294912
* = 3x384x256). Thus, it is believed the image data is uncompressed RGB.
* The forth IFD is the sweet spot of the CR2 file. It is a lossless JPEG
* compressed image of dimensions the size of the camera's photo sensor. Canon
* adds three proprietary TIFF tags which are of unknown meaning, except the Tag
* 0xC640 with values for the sample file {1, 2238, 2238} are described by Dave
* Coffin's as being 'slice' information. Peeking into the JPEG code of this
* section one finds the following markers: SOI (start of image), DHT (define 2
* Huffmann tables), SOF3 (start of frame for lossless, sequential, non-
* differential, Huffman coding), and SOS (start of scan). There are no RSTm
* (reset modulo-8) markers. The section is located at the end of the file, and
* it is this location which makes it easy to replace a 'valued added' version
* of the image with the original.
* Decoding lossless JPEG is similar (and simpler) to decoding CRW images. Like
* CRW images, the compressed data is organized as a concatenation of a Huffmann
* code (i.e. HufCode or codeword) followed by a variable length difference code
* (i.e. Diff) bit stream as shown below. Unlike CRW images the HufCode only
* conveys the number of bits required by Diff.
* ... | HufCode[nBits] | Diff[nBits] | ...
* Like CRW images, the compressed data is row organized with interleaved BAYER
* grid array data for that row. So with a BAYER grid of RG/GB, the even rows
* has interleaved HuffCode/Diff data for ...RGRGRG..., while the odd rows it is
* ...GBGBGB...
* Unlike CRW images, there are no 64 pixel blocks, rather it is the width of a
* row. The initial values at the beginning of each row is the RG/GB value of
* its nearest previous row beginning. For the first row, the initial row
* values are 1/2 the bit range defined by the precision. Thus for 12-bit
* precision:
* Pix[Row, Col] = Val
* Pix[0,0] = (1 << (Precision - 1)) + Diff
* Pix[0,1] = (1 << (Precision - 1)) + Diff
* and for n >= 1
* Pix[n,0] = Pix[n-2,0] + Diff
* Pix[n,1] = Pix[n-2,1] + Diff
* while for any other Row/Column
* Pix[R,C] = Pix[R,C-2] + Diff
* Also unlike CRW images the mapping of decoded rows into the image buffer is
* divided into four quadrants. It is unclear why Canon chose this method, but
* nonetheless it's there. The RAW image is divided into 4 equal sized
* quandrants:
* +------------------------+------------------------+ RAW Image
* | Quad 0 | Quad 1 |
* | Quad 2 | Quad 3 |
* The finished image inteleaves quadrants row segments 0/1 and interleaves
* quandrant rows segments 2/3 while combined quandrants 0/1 is located to the
* left and combined quadrants 2/3 are concatenated to the right:
* +------------------------+------------------------+ Finished Image
* | Quad0.Row0 | Quad2.Row0 |
* | Quad1.Row0 | Quad3.Row0 |
* | Quad0.Row1 | Quad2.Row1 |
* | Quad1.Row1 | Quad3.Row1 |
* | etc | etc |
* | Quad0.RowN | Quad2.RowN |
* | Quad1.RowN | Quad3.RowN |
* So it can be said that Quads 0 and 2 contain the same two BAYER grid colors
* and Quads 1 and 3 contain the other two BAYER grid colors.
* Like CRW images, the actual difference value contained in the Diff[nBits] is
* organized loosely as a signed magnitude number, but has its own specific
* rules. First, it should be noted that the value of nBits determines the
* range of the number. As an example if nBits = 3, then the magnitude (of a
* DiffVal that can be +/- this magnitude) is 4 <= magnitude <= 7, or more
* specifically:
* (1 << (nBits - 1)) <= DiffVal <= ((1 << nBits) - 1) // + DiffVal
* -(1 << (nBits - 1)) >= DiffVal >= -((1 << nBits) - 1) // - DiffVal
* If the most significant bit (MSB) of Diff[nBits] is one, then DiffVal is
* positive and has a magnitude directly represented by binary value of these
* bits. If however, the MSB is zero, then DiffVal is negative and has a
* magnitude that is the compliment of these bits. As an example if
* Diff[nBits=3] = 101, then DiffVal is 5, whereas if Diff[nBits=3] = 001, then
* DiffVal is -6.
* The size of the decompressed image is slightly larger than the final image
* size. A few extra 'black' rows added on top and bottom and a few extra
* 'black' columns may be added to the left and right (but none have been
* observed). These 'black' rows/columns along with a few additional RG/GB
* rows/columns make up a set of Trim rows/columns which are ultimately deleted
* to get the final 'as advertised' RAW image size. Other than noting that some
* of the Trim is 'black,' it is beyond the scope of this description to
* determine the method to find the optimum Trim rows/columns. As an
* observation, customized Trim may (or it may not) be encoded in the Firmware
* of camera so that that the final calibration of the image sensor reflects
* this Trim in a manner that places the center of the image sensor at the lens
* center.
* TIFF MakerNote:
* The TIFF Tag called MakerNote may be used by a manufacturer to embed any type
* of information. Canon uses this segment. Parsing of this proprietary
* segment follows the following data structures:
* typedef struct
* tU16 TagID;
* tU16 TagType;
* tU32 TagCnt;
* tU32 DataOfst;
* } tREC;
* typedef struct
* tU16 numRecords;
* tREC RecordDir[numRecords];
* tU8 Heap[];
* } tMAKERNOTE;
* The ordering of bytes is 'little endian' (Intel), but this is probably a
* function of the overall TIFF byte ordering. The first two bytes identifies
* the number of records (numRecords), and this is followed by the record
* directory (RecordDir), and this if followed by the Heap of various data.
* Each record directory consists of 12 bytes with 4 fields. The first field is
* the tag identification (TagID), followed by the tag type (TagType), followed
* by the tag count (TagCnt), and finally followed by data offset (DataOfst) or
* if the TagType is 4 then this field is immediate data. This format closely,
* but not exactly, follows standard TIFF.
* The TagType fields may have the following meaning:
* Type = 2: ASCII data
* Type = 3: tU16 data
* Type = 4: immediate data
* Type = 7: unknown
* The TagID fields may have the following meaning:
* TagType = 0x01: Camera settings 1
* TagType = 0x04: Camera settings 2
* TagType = 0x06: Camera model (string)
* TagType = 0x07: Camera F/W version (string)
* TagType = 0x08: Image number ???
* TagType = 0x09: Owner name (string)
* TagType = 0x0C: Camera serial number (immediate data number)
* TagType = 0x0F: Custom functions
* TagType = 0x95: Lens model (string)
* The following is an sample extraction:
* 02BC: 1D 00 =NumRecord
* -ID-- -Type ---Cnt--- --Ofst--- #
* 02BE: 01 00 03 00 2E 00 00 00 1E 04 00 00 1 - CameraSettings1
* 02CA: 02 00 03 00 04 00 00 00 7A 04 00 00 2
* 02D6: 03 00 03 00 04 00 00 00 82 04 00 00 3
* 02E2: 04 00 03 00 22 00 00 00 8A 04 00 00 4 - CameraSettings2
* 02EE: 06 00 02 00 0D 00 00 00 CE 04 00 00 5 - "Canon EOS 5D"
* 02FA: 07 00 02 00 18 00 00 00 EE 04 00 00 6 - "Firmware Version 1.1.0"
* 0306: 09 00 02 00 20 00 00 00 06 05 00 00 7 - OwnerName
* 0312: 0C 00 04 00 01 00 00 00 1F 15 CE 42 8 - CameraSerialNum = 0x42CE151F
* 031E: 0D 00 07 00 00 04 00 00 26 05 00 00 9
* 032A: 0F 00 03 00 17 00 00 00 76 09 00 00 a - CustomFunctions
* 0336: 10 00 04 00 01 00 00 00 13 02 00 80 b
* 0342: 12 00 03 00 28 00 00 00 26 09 00 00 c
* 034E: 13 00 03 00 04 00 00 00 A4 09 00 00 d
* 035A: 15 00 04 00 01 00 00 00 00 00 00 A0 e
* 0366: 19 00 03 00 01 00 00 00 01 00 00 00 f
* 0372: 83 00 04 00 01 00 00 00 00 00 00 00 10
* 037E: 93 00 03 00 10 00 00 00 AC 09 00 00 11
* 038A: 95 00 02 00 40 00 00 00 CC 09 00 00 12 = "EF24-105mm f/4L IS USM"
* 0396: 96 00 02 00 10 00 00 00 0C 0A 00 00 13
* 03A2: A0 00 03 00 0E 00 00 00 1C 0A 00 00 14
* 03AE: AA 00 03 00 05 00 00 00 38 0A 00 00 15
* 03BA: B4 00 03 00 01 00 00 00 01 00 00 00 16
* 03C6: E0 00 03 00 11 00 00 00 42 0A 00 00 17
* 03D2: D0 00 04 00 01 00 00 00 00 00 00 00 18
* 03DE: 01 40 03 00 1C 03 00 00 64 0A 00 00 19
* 03EA: 02 40 03 00 66 2B 00 00 9C 10 00 00 1a
* 03F6: 05 40 07 00 88 C0 00 00 68 67 00 00 1b
* 0402: 08 40 03 00 03 00 00 00 F0 27 01 00 1c
* 040E: 09 40 03 00 03 00 00 00 F6 27 01 00 1d
difference taille capteur et ouverture.
Par lolhangman dans le forum Discussions techniquesRéponses: 19Dernier message: 09/08/2012, 10h54 -
Taille du capteur
Par fudebu dans le forum Discussions généralesRéponses: 5Dernier message: 26/05/2010, 17h41 -
Taille du capteur
Par Mixcoatl dans le forum Discussions généralesRéponses: 3Dernier message: 06/08/2007, 13h55 -
taille de capteur
Par jipo1012 dans le forum Discussions généralesRéponses: 2Dernier message: 10/05/2007, 23h02 -
Fonctionnement du capteur et taille de sortie
Par xavierb dans le forum Discussions généralesRéponses: 5Dernier message: 24/12/2006, 15h52
