Discussion: Probleme avec le HDR
08/06/2006, 13h21 #7Membre
- février 2006
- 53
- 645
- 350D
- Tamron 17-50 - Canon 50/1.8 - Sigma 70-300 APO DG - M42
HDR Shop peut te convertir ton image HDR en n'importe quel format.
Edit:
Après une petite enquête du coté du site de Photomatix j'ai trouvé ça:
"I created an HDR image, why can't I save it as JPEG?"
An HDR image stores color information in 32-bit precision and as such can't be directly saved in a Low Dynamic Range format such as JPEG.
An HDR image in itself is not very interesting for photographers since it can't be correctly displayed on monitors and even less printed. This is why the HDR image you created from several exposures needs to be further processed for photographic use. It needs to be tone mapped so that the values of the image data fit into the limited range that your monitor can display.
Once you have applied the Tone Mapping tool to your HDR image, the details in highlight and shadows captured with your multiple exposures will then become visible on screen and you will be able to save the result as JPEG (or as 16-bit TIFF image if have selected the 16-bit output option).Dernière modification par Deufre ; 08/06/2006 à 13h27.
Problème avec mon 30D.
Par carpion dans le forum Discussions techniquesRéponses: 5Dernier message: 11/12/2007, 19h33 -
Problème avec DPP
Par fufu dans le forum Discussions techniquesRéponses: 7Dernier message: 25/05/2007, 16h14 -
Problème avec ma CF
Par scrapper dans le forum Discussions généralesRéponses: 21Dernier message: 06/07/2006, 20h08 -
probleme avec le 20 D
Par promano dans le forum Discussions techniquesRéponses: 6Dernier message: 28/12/2005, 09h31
