Affichage des résultats 1 à 45 sur 83
Discussion: Nouveauté Sigma 2010
    Par défaut Nouveauté Sigma 2010
    SIGMA APO 70-200mm F2.8 EX DG OS HSM
    February 21, 2010: The Sigma Corporation is pleased to announce the new Sigma APO 70-200 F2.8 EX DG OS HSM.This large aperture telephoto zoom lens incorporates Sigma’s original Optical Stabilizer function.
    The lens covers a medium telephoto range of focal lengths from 70mm to 200mm and has a large maximum aperture of F2.8 throughout the entire zoom range. The OS (Optical Stabilizer) function offers the use of shutter speeds approximately 4 stops slower than would otherwise be possible. For Sony and Pentax mount, the built-in OS function of this lens can be used even if the camera body is equipped with an image sensor shift anti-shake system.
    As compensation for camera shake is visible in the view finder, the photographer can easily check for accurate focus and ensure there is no subject movement. Two FLD (“F” Low Dispersion) glass elements, which have the performance equal to fluorite glass, and three SLD (Special Low Dispersion) glass elements provide excellent correction of color aberration.
    High image quality is assured throughout the entire zoom range and an optimum optical power layout provides superior optical quality in all shooting ranges from close-up to infinity. Super Multi-Layer Coating reduces flare and ghost. This lens incorporates HSM (Hyper Sonic Motor), ensuring a quiet and high speed AF as well as full-time manual focus capability.
    The lens has a minimum focusing distance of 140cm (55.1”) throughout the entire zoom range and a maximum magnification ratio of 1:8. The rounded 9 blade diaphragm creates an attractive blur to the out of focus images. This lens is equipped with a Petal-type hood. For digital cameras with an APS-C size image sensor, a dedicated hood adapter, which expands the length of the lens hood, is supplied.
    SIGMA 85mm F1.4 EX DG HSM
    ebruary 21, 2010: The Sigma Corporation is pleased to announce the new Sigma 85mm F1.4 EX DG HSM. This large aperture medium telephoto lens optimized for use with digital SLR cameras features a focal length of 85mm, ensuring a natural perspective.
    The large aperture of F1.4 is especially ideal for portrait and low light photography. When used on digital cameras with an APS-C size image sensor, the lens effectively becomes a 127.5mm F1.4 lens. One SLD (Special Low Dispersion) glass element and one glass mold element give excellent correction for all types of aberrations and ensure superior optical performance.
    This lens is equipped with a rear focus system that minimizes fluctuation of aberration caused by focusing. The Super Multi-Layer Coating reduces flare and ghost even in backlight photography. Incorporating HSM (Hyper Sonic Motor), this lens provides quiet and high speed AF as well as full-time manual focus capability. It features a minimum focusing distance of 85cm and a maximum magnification 1:8.6.
    This lens has a round 9 blade diaphragm which creates an attractive blur to the out of focus images. This lens is supplied with a Petal-type hood to block out extraneous light. For digital cameras with an APS-C size image sensor, a dedicated hood adapter, which expands the length of the lens hood, is supplied and enables the hood to block out extraneous light more effectively.
    17-50 DC OS HSM
    February 21, 2010: The Sigma Corporation is pleased to announce the new Sigma 17-50mm F2.8 EX DC OS HSM. This large aperture standard zoom lens is designed for digital SLR cameras and incorporates Sigma’s efficient OS function. It is a compact lens with an overall length of just 91.8mm (3.6”).
    This lens covers a focal length from 17mm wide angle and offers a large aperture of F2.8 throughout the entire zoom range, making it ideal for many types of photography such as portraiture and landscapes. The OS (Optical Stabilizer) function offers the use of shutter speeds approximately 4 stops slower than would otherwise be possible.
    For Sony and Pentax mount, the built-in OS function of this lens can be used even if the camera body is equipped with an image sensor shift anti-shake system. As compensation for camera shake is visible in the viewfinder, the photographer can easily check for accurate focus and ensure there is no subject movement.
    Two FLD (“F” Low Dispersion) glass elements, which have performance equal to fluorite glass, plus two glass mold and one hybrid aspherical lens, provide excellent correction for all type of aberrations. The Super Multi-Layer Coating reduces flare and ghost. This lens has superior peripheral brightness and provides sharp, high contrast images even at the maximum apertures.
    High image quality is assured throughout the entire zoom range. Incorporating HSM (Hyper Sonic Motor), the lens provides fast and quiet AF. The lens has a minimum focusing distance of 28cm (11”) throughout the entire zoom range and a maximum magnification ratio of 1:5. The rounded 7 blade diaphragm creates an attractive blur to the out of focus images. The inner focusing system eliminates front lens rotation, making the lens particularly suitable for use with the supplied petal-type lens hood and circular polarizing filters.
    SIGMA 8-16mm F4.5-5.6 DC HSM
    February 21, 2010: The Sigma Corporation is pleased to announce the new Sigma 8-16mm F4.5-5.6 DC HSM. This is the first ultra wide zoom lens with a minimum focal length of 8mm, designed specifically for APS-C size image sensors. This lens has an equivalent angle of view of a 12-24mm lens when used on digital cameras with an APS-C size image sensor.
    The wide-angle of view from 121.2 degrees* produces striking images with exaggerated perspective, enabling photographers to emphasize the subject. Four FLD (“F” Low Dispersion) glass elements, which have the performance equal to fluorite glass, compensate for color aberration. One hybrid aspherical lens and two glass mold elements give excellent correction for distortion and astigmatism.
    Incorporating an inner focusing system, the lens produces high definition images throughout the entire zoom range. The Super Multi-Layer Coating reduces flare and ghosting while superior peripheral brightness ensures high contrast images throughout the entire zoom range.
    This lens incorporates HSM (Hyper Sonic Motor), ensuring quiet and high speed AF as well as full-time manual focus capability. It has a minimum focusing distance of 24cm throughout the entire zoom range which allows photographers to emphasize the subject by creating exaggerated perspectives. This lens has a compact construction with an overall length of 105.7mm and a maximum diameter of 75mm.
    SIGMA APO 50-500mm F4.5-6.3 DG OS HSM
    February 21, 2010: The Sigma Corporation is pleased to announce the new Sigma APO 50-500mm F4.5-6.3 DG OS HSM.
    This is a 10x high zoom ratio ultra telephoto zoom lens incorporating Sigma’s original Optical Stabilizer function. This lens covers a wide range of focal lengths from 50mm to 500mm ultra telephoto. The OS (Optical Stabilizer) function offers the use of shutter speeds approximately 4 stops slower than would otherwise be possible.
    For Sony and Pentax mount, the built-in OS function of this lens can be used even if the camera body is equipped with an image sensor shift anti-shake system. As compensation for camera shake is visible in the view finder, the photographer can easily check for accurate focus and ensure there is no subject movement.
    Four SLD (Special Low Dispersion) glass elements provide excellent correction of color aberration. The Super Multi-Layer Coating reduces flare and ghost and ensures high image quality throughout the entire zoom range. This lens has a maximum magnification ratio of 1:3.1 (at the focal length of 200mm) making it ideal for close-up photography.
    This lens incorporates HSM (Hyper Sonic Motor), ensuring quiet and high speed AF as well as full-time manual focus capability. The addition of the optional 1.4x EX DG or 2x EX DG APO Tele Converters produce a 70-700mm F6.3-8 or a 100-1000mm F9-12.6 MF zoom lens respectively. This lens is equipped with a Petal-type hood to block out extraneous light. The filter size of this lens is φ95mm and the lens is supplied with a step down ring enabling digital cameras with an APS-C size image sensor to use an φ86mm filter.
    Une Grosse fournée 2010 ...
    Abonné Avatar de briceos
    Tout ceci est très alléchant sur le papier.
    Un concurrent du 70-200 F/2.8 Canon
    Un 85/1.4, pas mal ça !!
    Un rival du fameux EF-S 17-55 F/2.8 IS
    Et la grosse MAJ du bigma !
    Maintenant........ c'est toujours le même problème... Quel prix ? Et pour quel risque vis à vis de la pérennité de ce matériel ?
    Membre Avatar de lau-val
    perpignan
    7d grip & 400d & flash 430 ex
    dite un 8/16mm même sur un petit capteur ça va déformer un max l'image ?
    bon dieu j'ai pas fini mon choix j'étais parti sur un 10/20mm tarom me vl'a bien !!!
    Citation Envoyé par lau-val Voir le message
    Ce n'est pas la focale qui déforme, c'est la perspective. Donc effectivement, si tu te places très près d'un objet à 8mm (aussi à 10mm !), sa perspective est exagérée.
    Si c'était la focale qui déformait, le paysage que tu prends serait déformé aussi.
    Les déformations se sentent aussi même à 30 ou 50mm quand on est trop près de son sujet.
    Moi j'ai hâte de voir le test et le prix du 70-200 2.8 OS ... Le prix du MK II canon m'a complètement refroidit
    Thann (68)
    7D 5D mkII 430EXII
    17-50 F2.8, 70-200 2.8L, 24-70 2.8L, 35mm F2, 50mm 1.8 inversé
    Vivement le test du 85mm 1.4!
    Nantes
    Divers Canon
    hmmmmm, un Bigma stabilisé!!! :clap_1:
    Membre Avatar de bourriquet83
    CENTRE VAR
    EOS 60D
    pas beaucoup de version EX...
    Même le nouveau bigma à l'air d'etre passé dans la gamme expert.
    Mais y'a des cailloux vraiment sympa, espérons que les prix ne vont pas s'envoler. Maintenant c'est la mode, Sigma vends plus cher que Canon (voir son 50mm 1.4)
    Ils ne sont pas très cohérents avec le label EX. L'ancien bigma était connu pour sa bonne tenue "malgré" l'absence de label EX. Pour d'autres objectifs, c'est le contraire.
    Abonné Avatar de rem22
    5D mark II - 430ex2
    En même temps, pour les prix, le sigma 50mm f/1.4 est le plus piqué des objectifs 50mm entre f/1.4 et f/1.8, il mérite cet écart de prix finalement. Si Canon sortait un nouveau 50mm f/1.4, avec un aussi bon piqué, completement revu, je pense que le prix serait surement moins raisonnable. Pour moi, le pb du 50mm f/1.4, c'est plus ses erreurs de focus ( si on a pas de microréglages, inexploitable à grandes ouvertures, autant prendre le canon ) et les fameux err01.
    Concernant ces objectifs, je notre le 8-16 et le 85 f/1.4, qui pourrait être top pour les portraits serrés sur aps-c. Le problème, c'est que le 50mm f/1.4 a déjà du mal a faire correctement la mise au point, alors à 85mm f/1.4, j'ai vraiment peur !
    Quant au 70-200 f/2.8, peu de chance qu'il rivalise avec le f/2,8, car c'est un sacré investissement, vu les err01 possibles et les pb d'autofocus, difficile de rivaliser avec les canon 70-200L, à moins d'un prix cassé.
    De tous, c'est le "petit" 85mm f/1.4 qui me botterait le plus, vu qu'en 70-200 f/2.8 je pense que je prendrai au printemps le canon.
    Merci Fredo pour les news.
    Faut voir les tests et comparatifs a venir ... Mais ca sent quand même un très bon 85 ... Après savoir si la différence de prix avec un 85 1.8 et de qualité va être énorme ... Autre débat ... Bon il promet déjà un joli bokeh avec ses 9 lames ...
    Perso j'aimerai bien avoir le 85 1.4 et le 70-200 OS en main pour voir ce qu'ils ont dans le ventre ...
    Abonné Avatar de Helios
    +1, très intéressé de voir ce que donne ce 85mm, y a pas à dire il est alléchant, surtout si la qualité optique égale celle du dernier Sigma 50 f/1.4
    CENTRE VAR
    EOS 60D
    le vieux bigma est EX
    apres je ne sais pas spécialement ce que sigma fait de plus avec cette gamme "pro"; si c'est juste la finition ou si il y a des particularitées qu'on retrouve dans nos L
    edit: si je prends du sigma je ne prends que la gamme EX; la réputation est suffisament mauvaise de ce constructeur... alors je ne prendrais pas du bas de gamme chez eux.
    Dernière modification par bourriquet83 ; 21/02/2010 à 13h26.
    La dénomination EX est loin d'être clair chez Sigma ...
    Membre Avatar de davidemb
    EOS 30, 430 EX II, 6D
    135L, 100L, 24-105L, 85 F1.8 et sigma 35 F1.4 (et 17-40 malade car grosse chute...)
    c'est clair que si le 85 est très bon, ça sera une alternative non négligeable entre les F1.2 et F1.8 de canon...wait and see
    Nikon D700
    Tamron 24-70 & 70-200 2.8 Di VC USD, Nikkor 50mm 1.4 G, Nikkor 60mm Macro 2.8
    Euh question bête : pourquoi vous dites "Bigma" ?
    Sinon, je suis d'accord avec vous, acheter Sigma n'a de sens que si le prix est beaucoup moins cher à qualité optique comparable.
    La fiabilité et la construction étant largement à l'avantage de Canon.
    Le 70-200 2.8 OS HSM devrait se situer au niveau de prix du Canon non stabilisé voire en dessous, sinon aucun intérêt. Et puis si la formule optique est la même que sur celui qui existe déjà : apparemment c'est moyen.
    Le 85 1.4 c'est intéressant sur le papier, mais là aussi je préfère me contenter du 1.8 Canon (auquel je pense) si le Sigma est significativement plus cher.
    Opinion de quelqu'un qui a déjà goûté à la finition aléatoire des cailloux Sigma.
    Non la formule optique du nouveau 70-200 OS n'a rien a voir ... Les verres le composant et les ensembles sont tout a fait différent ... Je pense que l'on peut s'attendre a une bonne surprise au niveau optique ... Et faire moins cher que Canon je pense que Sigma doit pouvoir y arriver ...
    Nikon D700
    Je parlais de faire moins cher que le 70-200 L2.8 non IS, j'espère un prix magasin autour de 1200€.
    CENTRE VAR
    EOS 60D
    bigma est le surnom "affectif" du 50-500
    Nantes
    Divers Canon
    Citation Envoyé par Ignatius Voir le message
    Tout à fait. C'est la contraction de Big Sigma.
    Et sinon, le 50-500 faisait bien partie de la gamme EX
    Dernière modification par groux ; 21/02/2010 à 15h25.
    Moi perso je l'espère aussi dans ses eaux la ...
    Sans quoi pour préciser tout a l'heure :
    70-200 DG : 18 éléments en 15 groupes
    70-200 OS : 22 éléments en 17 groupes
    Vraiment neuf de A a Z celui la ...
    CENTRE VAR
    EOS 60D
    esperons qu'ils ne fassent pas le coup de leur 50mm. Ils l'estimes meilleur que la conccurence alors vente plus chere. (bon c'est vrai que le 50mm à une solide réputation)
    Canon EOS 5D Mark III
    Canon 24-105/4 L IS, Canon 70-200/2.8 II L IS, Canon 135L, Canon 100L, Sigma 35 1.4
    Pour le 70-200 OS, Je sais pas pour vous mais moi je suis inquiet de la position de la bague de zoom et de l'étroitesse de la bague de mise au point :blink: Sur la version actuelle, la bague de zoom se situe juste après le collier de pied , ce qui est bien pratique pour la stabilité de l'ensemble boitier/objectif. En tout cas, la photo de l'objectif me fait une impression bizarre, comme si l'objectif allait s'allonger ... J'espere me tromper.
    A voir.
    Très intéressé également par le 85 1.4:rolleyes:
    5D mark II - 430ex2
    Le pb Fredo, c'est aussi cette histoire d'err01. Si dans quelques années tu as ce pb sur un objectif à 1200€, ça fait mal. Pour ma part, j'investirai 1200e dans un 70-200 f/2.8, et honnetement, ça sera un Canon. Faudrait vraiment que le sigma soit top top top pour que je le prenne, et encore,tjs la crainte du fameux err01 ( et des f/b focus ).
    +1 Bourriquet sur le prix.
    Faut aussi voir les choses d'une autre façon...Zeiss fait un 85 f/1.4, manual focus et hors de prix. Canon fait un très bon f/1.8, bon af, abordable. Ils font un splendide f/1.2 hors de prix. Si sigma sort un 85 f/1.4 aussi bon que leur 50mm, avec un bon af, ça risque de faire très mal, et Canon devra ptet alors sortir un 85 f/1.4 à son tour. Ca serait top pour les portraits sur aps-c je trouve, une "presque" alternative au couple 24x36 + 135 f/2. Aujourd'hui, la seule alternative à ce couple mythique sur aps-c c'est le 85 f/1.2, trop cher pour la plupart d'entre nous.
    Dernière modification par rem22 ; 21/02/2010 à 14h08.
    suresnes
    eos 400d, eos 5D II
    canon 50 1.8;Tamron 28 75 2,8;canon 24-105;sigma 150 2.8 macro
    voila en fin le cailloux que j'attendais, un 50-500 stabilisé.:thumbup:
    le choix dans ces super zooms n'est pas facile, soit tres chers, soit pas de stab, soit trop court.
    reste à voir les tests de piqués et et le prix final, bigmat je t'attend.
    Abonné Avatar de Kinggarden
    Territoire de Belfort
    Canon - Tamron
    Citation Envoyé par gaelgbb Voir le message
    Pour sûr que celui-ci a des chances de plaire !
    mars 2009
    Belgique - Ruisbroek (Uccle )
    1Ds MkII + 5D MkII + 7D MkII
    Ahhh moi qui attendait un hypothétique 85mm 1.4 chez Canon, c'est Sigma qui le sort, en fonction de son prix je pense qu'il va très certainement compléter mon sac. Le Zeiss étant vraiment trop cher mais la qualité ça se paye
    Vivement un CR sur ce 85mm 1.4 patience patience arrgghhh
    Membre Avatar de olivier28
    mesvoisin
    400 F5.6 - 50f1,8 - 18-135 is - sigma 120-300
    merci pour ca FREDO .
    curieux de voir le 70/200 OS ainsi que son poids .
    laon
    Canon 50D
    Sigma 10-20 + canon 15-85 + Tamron 70-300vc + Canon 60 efs + Tokina 100 macro + flash
    Que de bonnes nouvelles!! perso le 50/150 f2.8 ne m'a pas déçu, l'OS serait aussi un gros + sur ce cailloux, le 17/50 me fait de l'oeil!!! Je risque de craquer! si tout e fois le prix est étudié....
    Messieurs pensaient à mettre un sou au ptit cochon de tps en tps, le PRINTEMPS arrive doucement!
    Citation Envoyé par cosmos02 Voir le message
    Moi si, et il m'a vacciné contre Sigma ...
  32. #32
    Modérateur Avatar de Mnemmeth
    Graz, Autriche
    7D, 5D3 a peine deballe
    La première photo du 85 1.4 donne une idée de la taille de la bête :
    http://a.img-dpreview.com/articles/p...a/SAM_1004.jpg
    ENORME !
    Euh ils se servent de l'apn comme porte clef ? (cf le machin en haut a gauche)
  33. #33
    Membre Avatar de 044
    mai 2009
    C'est le cable antivol... sur un boitier de démo qui ressemble beaucoup à un 20D ou 30D.
  34. #34
    aucun
    aucun
    8-16... c'est intéressant comme objectif.
    Un équivalent au 12-24 FF (bon chez Canon ça fait plutôt 13-26...)
    A voir si on pourra monter des filtres dessus...
  36. #36
    mai 2009
    Wow la taille du 85mm... costaud.
    J'ai très hate de voir les tests à PO du Sigma, car chez Canon le 85mm USM à f1.8 est déjà très bon.
    Sigma a la réputation de faire de bonnes focales fixes alors voyons voir.
    Le 70-200 f2.8 OS est très sexy sur le papier,
    mais quid des problèmes de front-focus, de compatibilité, et du positionnement prix par rapport au cylindre blanc que tout le monde connait ?
    Dernière modification par 044 ; 22/02/2010 à 10h46.
  37. #37
    mai 2009
    Apparemment la motorisation HSM se généralise chez Sigma. C'est bien !
    J'attends à présent qu'ils nous sortent pour le Full Frame un équivalent du Canon 16-35 f2.8 avec HSM.
    Mon ancien 20-40mm F2.8 s'en approchait, mais il avait un AF un peu trop capricieux.
  38. #38
    EOS, FD, FL, R, RF...
    mouais, moi je ne vois rien à faire grimper aux rideaux!
    Plusieurs choses à rectifier. la formule du 70/200 est la même que l'ancien, c'est juste l'ajout de l'OS qui fait augmenter le nombre de lentilles et de groupe (à noter quand même l'emploi d'une lentille copiée sur les fluorites de Canon).
    le 85 f/1.4? j'attends impatiemment de voir son prix! Si il est dans le même acabit que le 50 f/1.4, vraiment pas de raison de payer largement plus cher pour gagner 1/2 diaph face à un 85 f/1.8 USM qui est excellent.
    Quand au 50 f/1.4, il est certes légèrement plus piqué que le 50 f/1.4 de Canon à PO (au centre), par contre il est nettement plus sensible aux flare. De plus, si sa définition est forte, son contraste est faible et les couleurs sont plus chaudes, cette technique est souvent employée par Sigma pour compenser les écarts entre le centre et les bords.
    Dans l'absolu, le meilleur 50 mm reste le Zeiss.
    pour le reste, je ne me permettrait pas de comparer un 70/200 f/2.8 OS Sigma avec le 70/200 IS de Canon, les constructions étaient à 100 lieux! un L de Canon c'est fait pour les pros et encaisser sans broncher les aléas du temps, alors que les Sigma, malgré l'appellation EX pro, au mieux ont la finition d'un 85 f/1.8, c'est à dire gamme expert.
    je ne reviendrais pas non plus sur les risques d'incompatibilité dans le futur, on peut concevoir de payer moins cher une marque tiers, mais lorsque celle ci vend au même tarif voir plus cher (cf le 50 f/1.4) je trouve que c'est du foutage de gueule.
    Quitte à choisir, je préfère acheter de l'original, voir du Tamron ou Tokina qui ne connaissent pas les même soucis d'incompatibilité, mais bon après chacun fait comme il veut!
  39. #39
    perpignan
    c'est vrai canon passion mais tu oublis que tout le monde ne peut caser XXXX roro dans un objectif il sera difficile de faire plus cher que le nouveau 70/00 2.8 is non ?
  40. #40
    Ca c'est un faux problème! D'une part parce que nouveau 70/200 f/2.8 IS est moins cher que le précédent à sa sortie (3000€ en 2001), c'est logique qu'à la sortie d'un objectif, le tarif soit plus élevé, il descend ensuite petit à petit.
    Après il faut savoir ce que l'on veut! un L c'est fait pour durer, j'ai vu des 70/200 f/2.8 (non IS) de pros complètement usés avec de la peinture qui manquait de partout, ils fonctionnaient toujours parfaitement.
    Met un Sigma dans les même conditions, je ne donne pas cher de sa durée de vie! D'ailleurs les rares pros qui ont fait ce choix l'ont vite regretté!
    Que vaut il de mieux, payer plus cher mais être sûr de son achat (construction, fiabilité, compatibilité futur), ou paye run peu moins, mais avec une durée de vie nettement plus courte?
    Encore une fois, c'est une question de choix, je sais bien que la mode c'est le consommable mais quand même!
    pour ma part, si j'avais à m'équiper et que mes moyens étaient limités, je prendrais plutôt un 500D avec un 70/200 Canon, qu'un 7D avec un 70/200 Sigma.
  41. #41
    CENTRE VAR
    EOS 60D
    Sigma vois ses tarifs monter ses temps-ci; il vaut mieux mettre quelques € de plus et prendre du canon.
    Si encore sigma améliorait la fiabilité (faut voir le nombre d'utilisateurs qui gueulent car envoi au sav) et la compatibilité dans le futur cela pourrait etre une alternative.
    L'avantage de sigma c'est les petits prix en occase...
  42. #42
    perpignan
    mesieurs vous êtes bien gentils mais tout le monde ne peut mettre près de 3000 euro non mais ! et cela n'a rien a voir avec des choix cela s'appel le pouvoir d'achat si tu gagnes 1000 euro avec une famille va essayer de t'en offrir un .
    alors si tu veux t'amuser quand même tu t'offres moins cher, voir un 70/300mm à 200 euro.
  43. #43
    CENTRE VAR
    EOS 60D
    N'oublie jamais que si tu achete de l'occasion tu ne perds quasiment rien sur la revente!
    Alors à choisir autant prendre du bon materiel. (et que dire des vieux 75-300 canon qu'on vends aujourd'hui 120e en moyenne tandis que les objectifs sigma de la même époque vont à la poubelle vu qu'ils sont incompatibles!)
    Ensuite si tu prends du neuf pense que tu perdra moins sur du canon que sur du sigma...
    Sans parler des pb de de sigma sur ses objo qui t'obligent bien souvent à ramener l'objectif au magasin :p
    Apres comme je l'ai dit y'a de super coup à faire en occasion sur du sigma!! mais au détriment du pauvre gus qui l'a acheté neuf... J'avais payé mon bigma une misere.
  44. #44
    C'est comme pour tout, le pas cher est toujours trop cher!
    Pour le moment on ne sait pas à quel prix va sortir le 70/200 Sigma. Mais à supposer qu'il soit à 1500 €, soit 900 € de moins que le Canon (2400 €), on achète pas un objectif pour 1 ou 2 ans, mais plutôt pour 10 ans.
    Sur 10 ans, cela te reviens à 90€ par an, soit 7.50 par mois de plus !
    par contre au bout de 10 ans, ton 70/200 Canon vaudra a peut près en occasion 1300 € sans aucun soucis de fonctionnement, alors qu'au mieux le Sigma se revendra 500€, à supposer qu'il soit toujours en vie, sans garantie de compatibilité, ni de fiabilité!
    Je dirais que c'est justement quand on a des moyens limités que le moins cher est trop cher, celui qui a les moyens peut se permettre de jeter quand ça ne fonctionne plus, pas celui qui ne les a pas (les moyens)!
    Quand à l'argument des revenus, j'ai le souvenir de la rencontre en Camargue ou on avait vu arriver notre ami Enzorator avec une Logan, certains avaient un petit sourire en coin, petit sourire bien vite remplacé par une langue de 2 m de long lorsque du coffre de cette Logan est sortit un 400 f/2.8 L....
    Mais encore une fois, chacun fait comme il veut!
  45. #45
    Faut voir et attendre les tests ... La formule optique a l'air quand meme très différente ... Verres FLD en plus ... Moi je pense que ca peut être une bonne surprise ... Après certe si j'avais les moyens le MK II en IS je prendrais
  1. Nouveauté : Canon Eos 7D
    Par stilgarna dans le forum EOS 7D
    Réponses: 2661
    Dernier message: 01/09/2010, 16h54
  2. Réponses: 14
    Dernier message: 21/02/2010, 18h22
  3. Nouveauté Canon EF-S 18/200 f/3.5-5.6 IS
    Par Gerard 13 dans le forum Discussions Objectifs
    Réponses: 22
    Dernier message: 27/08/2008, 15h28
  4. Nouveauté ?
    Par fuji dans le forum Discussions techniques
    Dernier message: 10/11/2006, 08h41
  5. nouveauté
    Par Jibs dans le forum Discussions Flash
    Dernier message: 17/11/2004, 15h39
Fuseau horaire GMT +1. Il est actuellement 15h19.
