    Par défaut Liste des paresoleils Canon
    Fixes
    _____
    EF 14mm f/2.8 L USM_________________________ integre
    EF 15mm f/2.8 Fisheye_______________________ integre
    EF 20mm f/2.8 USM___________________________ EW-75 / II
    EF 24mm f/1.4 L USM_________________________ EW-83D / II
    EF 24mm f/1.4 L USM II______________________ EW-83K
    EF 24mm f/2.8_______________________________ EW-60 / II
    EF 24mm f/2.8 IS ___________________________ EW-65B
    EF 28mm f/1.8 USM___________________________ EW-63 II
    EF 28mm f/2.8_______________________________ EW-65 / II
    EF 28mm f.2.8 IS ___________________________ EW-65B
    EF 35mm f/1.4L USM__________________________ EW-78C
    EF 35mm f/2_________________________________ EW-65 / II
    EF 50mm f/1.0 L USM_________________________ ES-79 / II
    EF 50mm f/1.2 L USM_________________________ ES-78
    EF 50mm f/1.4 USM___________________________ ES-71 / II
    EF 50mm f/1.8 I_____________________________ ES-65 / II / III
    EF 50mm f/1.8 II ___________________________ ES-62 + adaptateur
    EF 50mm f/2.5 Compact Macro_________________ N/D
    EF-S 60mm f/2.8 USM Macro___________________ ET-67B
    EF 85mm f/1.2 L USM / II____________________ ES-79 / II
    EF 85mm f/1.8 USM___________________________ ET-65 II / III
    EF 100mm f/2 USM____________________________ ET-65 II / III
    EF 100mm f/2.8 USM Macro____________________ ET-67
    EF 100mm f/2.8 L IS USM Macro_______________ ET-73
    EF 135mm f/2 L USM__________________________ ET-78 II
    EF 135mm f/2.8 Soft Focus___________________ ET-65 II / III
    EF 180mm f/3.5 L USM Macro__________________ ET-78 II
    EF 200mm f/1.8 L USM________________________ ET-123
    EF 200mm f/2 L IS USM_______________________ ET-120B
    EF 200mm f/2.8 L USM________________________ integre
    EF 200mm f/2.8 L USM II_____________________ ET-83B / II
    EF 300mm f/2.8 L IS USM_____________________ ET-120
    EF 300mm f/2.8 L IS USM II__________________ ET-120 / W II
    EF 300mm f/2.8 L USM________________________ ET-118
    EF 300mm f/4 L IS USM_______________________ integre
    EF 400mm f/2.8 L II USM_____________________ ET-131B / II
    EF 400mm f/2.8 L IS USM_____________________ ET-155
    EF 400mm f/2.8 L IS USM II__________________ ET-155 / W II
    EF 400mm f/2.8 L USM________________________ ET-131B / II
    EF 400mm f/4 DO IS USM______________________ ET-120
    EF 400mm f/5.6 L USM________________________ integre
    EF 500mm f/4 L USM IS_______________________ ET-138
    EF 500mm f/4.5 L USM________________________ ET-123B / II
    EF 600mm f/4 L IS USM_______________________ ET-160
    EF 600mm f/4 L USM__________________________ ET-161 / II
    EF 800mm f/5.6 L IS USM_____________________ ET-155
    MP-E
    ____
    MP-E 65mm f/2.8 1-5x Macro__________________ Exclusif
    Bascule et decentrement
    TS-E 17mm f/4 L_____________________________ N/A
    TS-E 24mm f/3.5 L___________________________ EW-75B II
    TS-E 24mm f/3.5 L II________________________ EW-88B
    TS-E 45mm f/2.8_____________________________ EW-79B / II
    TS-E 90mm f/2.8_____________________________ ES-65 II / III
    Zooms
    _____
    EF 8-15mm f/4 L USM_________________________ EW-77
    EF-S 10-22mm f/3.5-4.5 USM__________________ EW-83E
    EF-S 15-85mm f/3.5-5.6 IS USM_______________ EW-78E
    EF 16-35mm f/2.8 L USM______________________ EW-83E
    EF 16-35mm f/2.8 L USM II___________________ EW-88
    EF 17-40mm f/4 L USM________________________ EW-83E
    EF-S 17-55mm f/2.8 IS USM___________________ EW-83J
    EF-S 17-85mm f/4-5.6 IS USM_________________ EW-73B
    EF-S 18-55mm f/3.5-5.6 / II / USM II / IS___ EW-60C
    EF-S 18-55mm f/3.5-5.6 IS II________________ A venir
    EF-S 18-135mm f/3.5-5.6 IS__________________ EW-73B
    EF-S 18-200mm f/3.5-5.6 IS__________________ EW-78D
    EF 20-35mm f/2.8 L__________________________ EW-75 / II
    EF 20-35mm f/3.5-4.5 USM____________________ EW-83 / II
    EF 22-55mm f/4-5.6 USM______________________ EW-60C / D
    EF 24-105mm f/4.0 L USM_____________________ EW-83H
    EF 24-70mm f/2.8 L__________________________ EW-83F
    EF 27-70mm F/2.8 L MK II ____________________ EW-88C
    EF 24-85mm f/3.5-4.5 USM____________________ EW-73 / II
    EF 28-105mm f/3.5-4.5 USM II________________ EW-63 / II
    EF 28-105mm f/4-5.6 USM_____________________ EW-63B
    EF 28-90mm f/4-5.6 III______________________ EW-60C
    EF 28-135mm f/3.5-5.6 IS USM________________ EW-78B / II
    EF 28-200mm f/3.5-5.6 / USM_________________ EW-78D
    EF 28-300mm f/3.5-5.6 L IS USM______________ EW-83G
    EF 28-70mm f/2.8 L USM______________________ EW-83B / II
    EF 28-70mm f/3.5-4.5 / II___________________ EW-68A
    EF 28-80mm f/2.8-4L USM_____________________ EW-79
    EF 28-80mm f/3.5-5.6 II / USM IV / USM V____ EW-60C
    EF 28-80mm f/3.5-5.6 USM____________________ EW-68A
    EF 28-90mm f/4-5.6 II / USM II______________ EW-60C
    EF 35-105mm f/4.5-5.6_______________________ EW-60B
    EF 35-105mm f/4-5.6 / USM___________________ EW-60B
    EF 35-135mm f/3.5-4.5_______________________ EW-68B
    EF 35-135mm f/4-5.6 USM_____________________ EW-62
    EF 35-350mm f/3.5-5.6 L USM_________________ EW-78 / II
    EF 35-70mm f/3.5-4.5 / A____________________ EW-68B
    EF 35-80mm f/4-5.6 II / III / USM___________ EW-54 / II
    EF 38-76mm f/4.5-5.6________________________ EW-54 / II
    EF 50-200mm f3.5-4.5 / L____________________ ET-62 / II
    EF 55-200mm f/4.5-5.6 USM___________________ EW-54 / II
    EF 55-200mm f/4.5-5.6 USM II________________ ET-54
    EF-S 55-250mm f/4-5.6 IS____________________ ET-60 III
    EF 70-200mm f/2.8 L IS USM__________________ ET-86
    EF 70-200mm f/2.8 L IS USM II_______________ ET-87
    EF 70-200mm f/2.8 L USM_____________________ ET-83 / II
    EF 70-200mm f/4 L USM / IS USM______________ ET-74
    EF 70-210mm f/3.5-4.5 USM___________________ ET-65 II / III
    EF 70-210mm f/4_____________________________ ET-62 / II
    EF 70-300mm f/4-5.6 IS USM / DO IS USM______ ET-65 / B
    EF 70-300mm f/4-5.6L USM IS_________________ ET-73B
    EF 75-300mm f/4.5-5.6 II / USM II / USM III_ ET-60
    EF 75-300mm f/4-5.6_________________________ ET-65 II / III
    EF 75-300mm f/4-5.6 USM IS__________________ ET-64 II
    EF 80-200mm f/2.8L__________________________ ES-79 II / EW-79
    EF 80-200mm f/4.5-5.6 USM / II______________ ET-54
    EF 80-200mm f/4.5-5.6EF 70-210mm f/4________ ET-62 / II
    EF 90-300mm f/4.5-5.6 / USM_________________ ET-60
    EF 100-200mm f/4.5 A________________________ ET-62 / II
    EF 100-300mm f/4.5-5.6 USM__________________ ET-65 II / III
    EF 100-300mm f/5.6__________________________ ET-62 / II
    EF 100-300mm f/5.6 LEF 100-300mm f/5.6______ ET-62 / II
    EF 100-400mm f/3.5-5.6 L IS USM_____________ ET-83C
    EF 200-400mm f/4 L IS USM extender x1,4_____ A venir
  1. Canon 400 F:5.6 L, des conseils?
    Par Pierjan2776 dans le forum Discussions Objectifs
    Dernier message: 30/12/2010, 21h22
  2. Concours 2011: Liste des thèmes du 1er trimestre
    Par canon-passion dans le forum Concours du mois
    Dernier message: 20/12/2010, 09h36
  3. Filtres
    Réponses: 131
    Dernier message: 20/01/2007, 21h32
  4. Quelques définitions des objectifs Canon
    Dernier message: 08/08/2004, 12h09
Fuseau horaire GMT +1. Il est actuellement 15h56.
