Voici la photo
Et les caract?ristiques (en anglais ...) :
Lightweight, compact and sturdy, tripod ideal for 35mm SLR cameras, especially when on the move outdoors.
Key features include:
four leg angle settings
centre column with an innovative three faced design
low angle adapter built in the centre column for ground level shots
legs collars with double wing locking knob
SPECIFICATIONS
Finish: Silver
Material: Anodized Aluminum
Series: 3001
Still Photography: Yes
Video: Yes
Sports Optics: Yes
Column Type: Rapid
Maximum Height with extended center column: 145 cm (57.1 inches)
Maximum Height: 116 cm (45.7 inches)
Minimum Height: 17 cm (6.7 inches)
Closed Length: 53 cm (20.9 inches)
Leg Sections: 3
Foot Type: Rubber
Maximum Load Capacity: 5.0 kg (11.1 lbs)
Head Mount: 3/8" threaded mount
Weight: 1.8 kg (3.9 lbs)
