    utilisateur
    septembre 2005
    dtc
    x
    z
    Par défaut support des makernotes dans photoshop ?
    lo,
    lorsque je visualise un jpeg venant de mon 350d avec irfanview je vois ces infos exif :
    Code:
    Make - Canon
    Model - Canon EOS 350D DIGITAL
    Orientation - Top left
    XResolution - 72
    YResolution - 72
    ResolutionUnit - Inch
    DateTime - 2005:11:09 15:04:24
    YCbCrPositioning - Co-Sited
    ExifOffset - 196
    ExposureTime - 1/200 seconds
    FNumber - 3.50
    ExposureProgram - Manual control
    ISOSpeedRatings - 100
    ExifVersion - 220
    DateTimeOriginal - 2005:11:09 15:04:24
    DateTimeDigitized - 2005:11:09 15:04:24
    ComponentsConfiguration - YCbCr
    ShutterSpeedValue - 1/200 seconds
    ApertureValue - F 3.50
    ExposureBiasValue - 0.00
    MeteringMode - Multi-segment
    Flash - Not fired, compulsory flash mode
    FocalLength - 200 mm
    UserComment -
    FlashPixVersion - 100
    ColorSpace - sRGB
    ExifImageWidth - 3456
    ExifImageHeight - 2304
    InteroperabilityOffset - 9230
    FocalPlaneXResolution - 3954.23
    FocalPlaneYResolution - 3958.76
    FocalPlaneResolutionUnit - Inch
    CustomRendered - Normal process
    ExposureMode - Manual
    WhiteBalance - Auto
    SceneCaptureType - Standard
    Maker Note (Vendor): -
    Macro mode - Normal
    Self timer - Off
    Quality - Fine
    Flash mode - Not fired
    Sequence mode - Continous
    Focus mode - AI Focus
    Image size - Large
    Easy shooting mode - Manual
    Digital zoom - None
    Contrast - High , +1
    Saturation - High , +1
    Sharpness - High , +1
    ISO Value - 32767 (other)
    Metering mode - Evaluative
    Focus type - Auto
    AF point selected -
    Exposure mode - Manual
    Focal length - 70 - 200 mm
    Flash activity - Not fired
    Sequence number - 0
    White Balance - Auto
    Image Type - Canon EOS 350D DIGITAL
    Firmware Version - Firmware 1.0.2
    Owner Name - unknown    <      P      d
    Camera Serial Number - xxxxxxxxxxxxx
    et après redimensionnement dans photoshop :
    Code:
    Make - Canon
    XResolution - 72.00
    YResolution - 72.00
    Software - Adobe Photoshop CS2 Windows
    DateTime - 2006:01:17 23:11:48
    ExifOffset - 228
    FNumber - 3.50
    ExifVersion - 220
    UserComment -
    ColorSpace - sRGB
    ExifImageWidth - 80
    ExifImageHeight - 53
    InteroperabilityOffset - 928
    WhiteBalance - Auto
    les précieux makernotes, me permettant de savoir "à coup sûr" que l'objectif utilisé est un 70-200, ont disparu
    après le coup du "sauvegarder pour le web" qui enlève carrément les exif ça fait vraiment pas sérieux de la part d'un tel logiciel je trouve
    le redimensionnement avec irfanview ne perd pas ces infos exif je le sais, mais j'avais pensé à utiliser les scripts de photoshop pour régler mon problème de "double resize" que j'ai évoqué ici
    peut-être ces makernotes sont conservées avec un plugin, je ne sais pas, en tout cas sur le net je ne suis pas le seul à trouver regrettable que des infos soient perdues lors de la sauvegarde
    si vous avez des pistes ça m'intéresse
    Membre Avatar de chriscb
    Colombes
    1Ds Mark II, 5DMkII, 10D
    85/f1.2 L II USM, 28-300 L USM IS, 50/f1.4, 24-70 f/2.8 L
    Juste un détail, "Sauvergarder pour le WEB" ça enlève les EXIF si tu lui demandes. Il y'a une case à cocher pour ça.
  1. Outil transformation dans Photoshop
    Par doc dans le forum Les Logiciels photo
    Dernier message: 22/09/2007, 18h56
  2. images en raw dans photoshop elements 5?
    Par RIRI dans le forum Les Logiciels photo
    Dernier message: 07/06/2007, 19h03
  3. Taille des textes dans Photoshop
    Par TNK dans le forum Les Logiciels photo
    Dernier message: 02/08/2006, 14h05
  4. Recuper les exifs dans photoshop?
    Par DarkFab dans le forum Les Logiciels photo
    Dernier message: 02/01/2006, 19h08
  5. effet halo dans photoshop
    Par scarface dans le forum Discussions techniques
    Dernier message: 27/09/2004, 21h00
Fuseau horaire GMT +1. Il est actuellement 02h05.
