Discussion: boule lyonnaise
    Membre Avatar de le gone
    lyon
    eos 10D
    18-50 EF
    Par défaut boule lyonnaise
    a vos commentaires
    Membre Avatar de ayato
    martigues
    censuré
    pas très net et un peu surex, la vitesse est peut-être trop lente.
    envoie les exifs stp
    (rien ne vaut la pétanque....)
    Europe
    appareil photo
    des bons
    Citation Envoyé par ayato Voir le message
    Les exif y sont
    """""Exif IFD0
    * Camera Make = Canon
    * Camera Model = Canon EOS 10D
    * Picture Orientation = normal (1)
    * X-Resolution = 180/1 = 180
    * Y-Resolution = 180/1 = 180
    * X/Y-Resolution Unit = inch (2)
    * Software/Firmware Version = Adobe Photoshop CS Windows
    * Last Modified Date/Time = 2008:08:08 16:20:23
    * Y/Cb/Cr Positioning (Subsampling) = centered / center of pixel array (1)
    Exif Sub IFD
    * Exposure Time (1 / Shutter Speed) = 1/20 second = 0.05 second
    * Lens F-Number/F-Stop = 56/10 = F5.6
    * ISO Speed Ratings = 100
    * Exif Version = 0221
    * Original Date/Time = 2008:08:04 17:47:34
    * Digitization Date/Time = 2008:08:04 17:47:34
    * Components Configuration = 0x01,0x02,0x03,0x00 / YCbCr
    * Compressed Bits per Pixel = 3/1 = 3
    * Shutter Speed Value (APEX) = 283242/65536
    Shutter Speed (Exposure Time) = 1/20 second
    * Aperture Value (APEX) = 325770/65536
    Aperture = F5.6
    * Exposure Bias (EV) = 0/2 = 0
    * Max Aperture Value (APEX) = 236894/65536 = 3.61
    Max Aperture = F3.5
    * Metering Mode = pattern / multi-segment (5)
    * Flash = Flash did not fire
    * Focal Length = 18/1 mm = 18 mm
    * User Comment (Hex) = User Comment Character Code = not defined
    * FlashPix Version = 0100
    * Colour Space = sRGB (1)
    * Image Width = 750 pixels
    * Image Height = 458 pixels
    * Focal Plane X-Resolution = 3072000/892 = 3443.95
    * Focal Plane Y-Resolution = 2048000/595 = 3442.02
    * Focal Plane X/Y-Resolution Unit = inch (2)
    * Image Sensing Method = one-chip color area sensor (2)
    * Image Source = digital still camera (DSC)
    * Custom Rendered = custom process (1)
    * Exposure Mode = auto exposure (0)
    * White Balance = auto (0)
    * Scene Capture Type = standard (0)"""
    Est-ce un flou de bouger? 1/20 seconde à f/18...
    Une map mal faite ?
    Un traitement sous photoshop inadapté?
    Difficile à dire.
    Sinon les attitudes sont assez bien vues, manque le pot de Beuj....s!
    Membre Avatar de Plettil
    EOS 600, RT, ....
    sans elle, sans aile .... sans L!
    bof, à refaire en ne rattant pas la photo.
    Devrait être nette avec la bonne vitesse, ne pas couper les pieds du msieur et éviter quelqu'un à moitié sur la photo (à droite)
    il faut changer les ISO car sauf maîtrise très bonne, il est impossible de faire une photo nette à moins de 1/60ieme quel que soit l'objectif. Ou alors il te faut un trépied.
    bonne continuation,
    Plettil
    Europe
    appareil photo
    des bons
    Citation Envoyé par Plettil Voir le message
    Plettil
    Étonnant cette affirmation...
    J'aurais appris quelque chose aujourd'hui. Je vais enfin pouvoir faire des photos au 1/60 s à 135 mm. Merci pour l'info.
    Membre Avatar de regis
    vesoul haute saone
    d300
    noir et doré
    c est claire qu a 1/20 faut du self control tout de meme , pas impossible mais risqué , sinon j aime bien la compo
    EOS 600, RT, ....
    Citation Envoyé par ac3 Voir le message
    hello,
    La règle que l'on lit partout, de l'inverse de la focale est vrai jusqu'à un certain point.... faire du 1/20ieme en 18mm....cela donne un flou de bougé, c'est ce que je voulais dire.
    Ce que je voulais dire c'est que quelle que soit la focale, descendre en dessous de 1/60s à main levée est assez difficile.
    Maintenant si tu es tireur de compétition et que tu as une maitrise particulière de tes tremblements et de ta respiration, tu peux tenter 1/60s ou moins au 135mm .... mais sache que tu as des chances de faire un flou de bouger, la position des pied, des mains, etc...sont primordiales...de même que le sujet qui doit pas bouger :blink: . Dans tous les cas, le piqué ne sera pas au "rasoir" mais satisfaisant pour un tirage 10x15.
    Cordialement,
    Plettil
    Europe
    appareil photo
    des bons
    hello,
    Cordialement,
    Plettil
    C'était juste de l'humour pour me moquer de ton affirmation incomplète.
    Dans ce que tu dis maintenant, n'oublies pas de multiplier par 1,6.
    EOS 600, RT, ....
    C'était juste de l'humour pour me moquer de ton affirmation incomplète....
    taquin va!
    martigues
    censuré
    et la pétanque?
    Europe
    appareil photo
    des bons
    et la pétanque?
    C'est de la boule lyonnaise... Tu sais, à Lyon, dans le nord, là où il fait froid.
    Trop Surex .... Et trop flou aussi Cadré trop large aussi, le toit et l'arbre n'apporte pas grand chose. M'enfin j'ai fait pire au début CONTINUE ! (PS : Que le premier Eosien qui a été bon dés sa première tof lance le cochonnet ! )
  1. Première boule...
    Par koalad1 dans le forum [Inclassable]
    Dernier message: 29/08/2010, 14h05
  2. une classique lyonnaise
    Par le gone dans le forum [Paysage]
    Dernier message: 05/08/2008, 17h55
  3. Boule
    Par Boule dans le forum Présentations & règlements
    Dernier message: 01/04/2008, 12h26
  4. Ca me met en boule !
    Par Panoramix dans le forum [Faune] Domestiques - Parcs - Zoos
    Dernier message: 04/07/2007, 00h30
  5. boule
    Par lagachette dans le forum [Graphisme]
    Dernier message: 09/01/2007, 18h55
Fuseau horaire GMT +1. Il est actuellement 12h27.
