Discussion: Firmware Russe
    Voil? ce que la version d?finitive doit donner :
    ?Wasia B7 firmware? for the Canon Digital Rebel (300D)
    Released June 1, 2004
    All enhancements
    ? Custom function menu found on the last page in the menu
    ? Ability to define how the SET button behaves (same menu found on the 10D - refer to the 10D manual for full
    explanation of these new enhancements)
    ? Exposure level increments either 1/2 or 1/3-stop
    ? Option to enable 1/200th flash speed sync in AV mode
    ? Ability to change the JPG size when shooting in RAW mode
    ? Shutter release with or without CF card
    ? FEC adjustment via the JUMP button, use the dial to adjust as shown on the LCD
    ? ISO3200 now available, and is represented by an "H" in the LCD - same as how the 10D shows this
    ? Mirror lockup available via enabling the option in the custom function, works by pressing the shutter button which
    flips the mirror up, then the shutter opens about 1-1.5 seconds after MLU - note that this is different than how it is
    implemented on the 10D where you press once to flip the mirror and press again to open the shutter
    ? Immediately pressing the ERASE button after taking a photo, you can delete the photo by pressing the ERASE
    button again instead of selecting Ok previously, to not delete the photo press any other key
    ? Left button changes the focus mode and is displayed on the LCD as follows:
    o PA-0 Lens set to manual focus
    o PA-1 One shot
    o PA-2 AI-Servo (selectable but cannot take a photo - one workaround, hold the shutter button all the
    way down then switch the lens to manual focus)
    o PA-3 AI-Focus (first takes one shot then the camera may switch to AI-servo depending on what you are
    focussing on)
    ? Right button is for changing something (believe it's metering) but this does not do anything - so ignore (values if
    you're curious are PA-0, PA-1 and PA-2)
    Custom Function Menu
    For further explanations on these custom functions please refer to the 10D manual.
    CF1 SET button func. when shooting (works)
    0 Default (no function)
    1 Change quality
    2 Change parameters
    3 Menu display
    4 Image replay
    CF2 Shutter release w/o CF card (works)
    0 Possible without CF card
    1 Not possible
    CF3 Flash Sync speed in Av mode (works)
    0 Auto
    1 1/200sec (fixed)
    CF4 Shutter button / AE lock button
    0 AF/AE Lock
    1 AE Lock/AF
    2 AF/AF lock, no AE lock
    3 AE/AF, no lock
    CF5 AF-Assist Beam / Flash firing
    0 Emits/Fires
    1 Does not emit/Fires
    2 Only ext. flash emits/Fires
    3 Emits/does not fire
    CF6 Exposure level increments: (works)
    0 1/2-stop
    1 1/3 stop
    CF8 RAW+JPEG rec. (works)
    0 RAW+Small Normal
    1 RAW+Small Fine
    2 RAW+Medium Normal
    3 RAW+Medium Fine
    4 RAW+Large Normal
    5 RAW+Large Fine
    CF9 Bracket. sequence/auto cancel
    0 0,-,+/enable (300D default)
    1 0,-,+/disable
    2 -,0,+/enable
    3 -,0,+/disable
    CF10 Superimposed display
    0 on
    1 off
    CF11 Menu button display position
    0 previous(top if powered off)
    1 previous
    2 top
    CF12 Mirror lockup (works)
    0 disable (300D default)
    1 enable
    CF14 Auto reduction of fill flash
    0 enable (300D default)
    1 disable
    CF15 Shutter curtain sync [NO]
    0 1st curtain sync
    1 2nd curtain sync
    CF16 Safety shift in av or tv
    0 disable
    1 enable
    CF17 Lens af stop button function
    0 af stop
    1 af start
    2 ae lock while metering
    3 af point: m->auto/auto-ctr.
    4 one shot -> <- ai servo
    5 IS start
    Watchouts
    ? Camera may lock up if you attempt to change the language, maybe possible to change the language but
    must be done on the original Canon 300D 1.1.1 firmware
    ? Some features may not work correctly if you are using another language - use English as a workaround
    ? If you upgrade and some of the things don&#39;t seem to work properly, set the settings in the Custom
    Function back to the original values (see below) and install the original 1.1.1 firmware, then upgrade to
    the new firmware
    ? Change the SET button to something other than FEC before upgrading to this version
    ? When the MLU is enabled and using the self timer, the timer will countdown and beep for 2 seconds then
    pause another 7-10 seconds with no countdown in the LCD or beep.
    ? Names for modes via left/right button will be updated to something more meaningful
    ? MLU does not work properly when using a flash ? flash will fire when the mirror is lifted ? not when the
    shutter opens
    Revertng back to the original version
    ? Reset all the Custom Function values to the original 300D settings. Note, you cannot use the Reset
    option in the menu, it does not affect these values. Below is a list of default binary values from left to right
    (the bottom numbers in the CF menu):
    0,0,0,0,0,1,0,11,0,0,0,0,0,0,0,0,0
    ? Flash back to 1.1.1.
    Voil? en croisant les doigts
    A plus
    baylyns
    c&#39;est celle qui doit sortir fin juin celle-l
    oui pr?vu fin juin &#33;
    mai 2004
    Nogent sur Oise
    E300d, E30d, E600d
    18/50 Sigma, 18/200 Canon, 300 F4L Canon
    A la lecture du mail de Felin, je n&#39;ai pas identifi? de diff?rences r?elles entre la version d?finitive qui devrait sortir fin Juin et la version Beta B7 actuelle.
    En particulier, la version d?finitive ne semble pas g?rer l&#39;autofocus continu (AI-servo, PA-2) et le mode de mesure de l&#39;exposition (matricielle, pond?r?e, spot).
    Ai-je mal lu?
    Joel.
    bsr,
    Th?oriquement la version finale sera celle qui est indiqu?e ci-dessus avec les options d?brid?es
    A plus
    Dans un ?ni?me magazine : objectif photo qui donne 9 au nikon D70 et 8,5 au 300 D, je lisais ce qui les diff?renciais c&#39;est ce qu&#39;apporte ce firmware hack
    mai 2004
    Tamron 17-50 f2.8; Sigma 70-200 f2.8, Sigma 10-20, Canon 50 f1.8
    J&#39;ai une petite question pratique :
    Apr?s l&#39;application du firmware, peut on revenir en Fran?ais pour les menus ou est-ce que l&#39;anglais est impos? ?
    PEP
    PEP
    il faut appliquer le fw dans la langue utilis?e et ?a reste...
    Sinon j&#39;ai flash? une fois, suis revenu en arri?re ?a marche, et je l&#39;ai reflash? ?a marche toujours
    mai 2004
    Beauvais
    350D
    Une nouvelle version du firmware Russe est disponible depuis hier la B71. Mais il y a apparemment tr?s peu de changement.
    c&#39;est par ici http://satinfo.narod.ru/en/download.html
    Steph
    oui sinon les mode ai os sont mieux indiques mais c&#39;est mineur
  1. je veux installer le firmware russe mais ou??
    Par jofjof27 dans le forum Canon
    Dernier message: 09/02/2005, 22h00
  2. Problème de l'autofocus avec le firmware russe
    Par Xtofthetof dans le forum EOS 300D
    Réponses: 17
    Dernier message: 09/02/2005, 11h12
  3. Régressions fonctionnelles Firmware Russe
    Par maxip dans le forum Canon
    Réponses: 25
    Dernier message: 29/11/2004, 21h59
  4. firmware russe + autofocus
    Par valerian dans le forum Canon
    Dernier message: 19/08/2004, 22h33
  5. Firmware russe / Mesure spot ?
    Par Breizh dans le forum Canon
    Dernier message: 16/08/2004, 09h28
Fuseau horaire GMT +1. Il est actuellement 21h16.
