Affichage des résultats 1 à 39 sur 39
    février 2005
    Mantes la Jolie
    2.8/80-200 série L, 18-55 USM, 28-105 USM, Sigma 8mm
    bonsoir,
    je ne l'ai pas test? mais voici les infos :
    UnDutchables V0.1.0
    le lien : http://www.syeager.org/300d/forum/index.ph...type=post&id=97
    The Wasia firmware already contained:
    - ISO 3200
    - Mirror Lock up for Timer and Single shot
    - Selectable pause for mirror lock up see C.Fn. 17
    - FEC on JUMP button
    - 'Left' button selects the autofocus mode:
    AF OS - ONEShot
    AF SE - AI-Servo (doesn't work right now)
    AF AI - AI-Focus
    - the default button in delete prompt was changed from 'Cancel' to 'OK'. So, be aware.
    Now if you want to delete an image, press DEL button and then SET one. To Cancel press any other key.
    Added functionality by the UnDutchables
    Continues Drive in Basic Mode
    Jump = FEC only selectable in Creative modes
    Left key = AF-Mode only selectable in Creative modes
    WB selection in Basic modes
    Custom Function 1 available in basic modes enabling:
    - Quality Select via SET button
    - Parameter select via SET buttons
    - Menu via SET button
    - Image Replay via SET button
    Working; Setting have to be changed in via Advanced mode
    WB-Bracketing
    Notes:
    1) Changing Quality in Basic mode may crash the camera. Nothing serious just turn the camera OFF and ON again. Changes must be made in a Creative modes or via the SET button + Custom Function-1 (see 10D manual page 166)
    2) If the AF drive is set to AI-Servo the AF confirmation Ligh and Beep are turned off (as done in the 10D) but now it is turned off for all ALL modes. Please change to AI-Focus or One-Shot if AF confirmation Light and Beep is desired.
    Have Fun
    The UnDutchables
    Emmanuel
    Membre Avatar de yffic
    juin 2004
    EOS 5d mark3
    16-35/2.8LII, 28-75/2.8
    Ca y est apres le russe, voici le firmware hollandais:
    http://www.syeager.org/300d/forum/in...?showtopic=110
    Il est disponible depuis ce soir....
    Yffic
    Abonné Avatar de TransFXB
    juin 2004
    Lyon - Rhône -69
    EOS 20D et 40D
    merci pour l'info Yffic.
    Gwenadu, tu le mets ?
    TransFXB
    février 2005
    Mantes la Jolie
    c'est drole, l'heure de ma r?ponse est avant celle du premier post ... j'?tais le premier mais me suis fait doubler. :blink:
    No problem, je suis nouveau inscrit sur le forum et le but est que l'information circule.
    ? bientot
    Emmanuel
    Membre Avatar de querido
    Gers: département 32
    5D MKII
    canon 400 f5.6 //24-105 f4 IS// 70-200 f4 is usm // sigma 150 f2.8 // tamron 17-35
    le fichier zip que je t?l?charge est vide...
    Membre Avatar de Jomanix
    août 2004
    Metz
    EOS 40D
    Sigma 70-300 APO, Canon EFS 18-55 & Sigma 18-200
    ??? Ben non, le mien est plein. :P En fait, c'est le firmware d'origine Wasia avec le m?me nom (E3KR111.zip) mais modifi? par les bataves.
    Membre Avatar de tetrapack
    avril 2004
    Vienne dans l'Isère
    Can 24-105, 70-200 2.8IS, 50 1.8, 100 2.8, Sig 135-400, Zenitar 16, Peleng 8
    Je n'ai pas tout compris, il apporte quoi en plus ce soft ?
    J'ai bien vu la liste des fonctions du soft Russe (FEC, forcage AF OS, relev? du miroir, blocage sans CF) qui est repris, mais cot? am?lioration :unsure:
    août 2004
    Canon EOS R50
    RF-S 18-45MM F4.5-6.3 IS STM - RF 100-400MM F5.6-8 IS USM
    - RAW dans les modes programme (y compris sport)
    - Balance des blancs dans les modes programme (y compris sport)
    - Prise de vue en rafale possible dans tous les modes programme
    - Bouton "Set" customisable en modes programme via CF1
    avril 2004
    Un champ requis appelé Lieu d'habitation est manquant ou a une valeur incorrecte.
    Un champ requis appelé Boitier est manqu
    Un champ requis est manquant ou a une valeur incorrecte.
    Je poss?de tjrs le firmware d'origine et je comptais peut-?tre mettre le russe, mais l? j'h?site... qqun a essay? ?
    S.
    juin 2004
    Lyon - Rhône -69
    EOS 20D et 40D
    sakana, tu peux y aller avec le russe, pas de pb.
    pour le dutch, je ne sais pas. Et les fonctionnalit?s apport?es (principalement dans les modes programmes, que j'utilise peu) ne semblent pas justifier sont utilisation, pour l'instant.
    TransFXB
    Membre Avatar de Fred08
    avril 2004
    C'est bien ?a, le raw en mode sport !
    avril 2004
    Vienne dans l'Isère
    Je suis bien de ton avis TransFXB,
    la bonne nouvelle en fait c'est que quelqu'un s'interesse encore ? modifier ce logiciel du 300D :
    toujours en attente :
    - possibilit? de forcer l'AF en suivi,
    - possibilit? de forcer le mode d'expo.
    Tetra
    J'avais le firmware russe et j'ai upgrad? avec le nouveau pour l'instant pas de probl?me
    avril 2004
    Le raw fonctionne en mode sport ?
    oui fred
    décembre 2004
    Beaujolais
    Réussir dans la vie, être aimé, des concerts de 100 mille personnes, .....
    Si j'ai bien suivi (je ne l'ai pas essay?), il permettrait aussi de choisir l'iso dans le mode sport ? Non ? Parce que jusqu'? pr?sent on est en ISO 400 par d?faut et il me semble que c'est le seul moyen d'obtenir l'AI SERVO (? moins de faire des bidouilles avec des prises jack).
    Est-ce qu'on peut vraiment shooter ? 100 ISO dans le mode sport, et en RAW, avec ce firmware d?tourn? ?
    Iso reste ? 400 dans le mode sport mais le format raw est accept?
    avril 2004
    Merci F?lin. J'attends un peu pour voir si tu n'as pas de probl?mes
    février 2005
    Cannes
    5D + 300 D
    EF 24-105L IS , EF 17-40 L , EF 100-400L IS, EF 50 1.8 II, Sigma 10-20, Tamron 28-300
    Je viens de faire l'upgrade du "russe au hollandais". Si je peux bien changer la WB en mode basique (sport ou portrait par exemple), par contre je n'ai pas acc?s au format RAW. Seules les d?finitions Hautes (x2), Moyennes (x2) et Basses (x2) sont disponibles via le menu "Qualit?".
    Tu as fait comment pour activer le RAW dans ces modes ??
    J'ai d? rater un ?pisode :blink:
    Pour passer en mode RAW en mode programme sport etc.. il faut se mettre en mode AV ou TV ou M ou P et dans le menu se mettre en mode RAW. Apr?s tu passes en mode sport et tu es toujours en RAW.
    Autrchêne (90 - Belfort 15Km)
    EOS 300D
    canaon 18-55 , 10-22, 100 macro, 100-300/4,5-5,6. Sigma 18-125
    je crois avoir compris que su tu configure la touche SET pour le choix de la qualit? (custom fonction 1), tu peux faire la s?lection ? l'aide de cette touche en ?tant dans un mode basic (sport par exemple)
    février 2005
    Cannes
    5D + 300 D
    Merci pour l'astuce...
    Une autre question. A quoi correspondent les mode :
    AF OS - ONEShot
    AF SE - AI-Servo
    AF AI - AI-Focus
    J'ai un peu de mal ? cerner la diff?rence entre AF OS - ONEShot et AF AI - AI-Focus.
    :huh:
    juin 2004
    Lyon - Rhône -69
    EOS 20D et 40D
    "UnDutchables 0.1.0 firmware" pour Canon 300D (Digital Rebel)
    Version de f?vrier 2005.
    Liste des am?liorations par rapport au firmware Canon d'origine 1.1.1
    Fonctions d?j? pr?sentes dans le firmware russe
    ? Menu fonctions personnalis?es disponible dans la derni?re page du menu d'origine.
    ? Possibilit? de d?finir le comportement du bouton SET
    ? Incr?ments de niveau d'exposition en 1/3 au lieu de ?
    ? Option pour activer la synchro flash au 1/200 en mode Av
    ? Possibilit? de changer la taille des JPG quand le mode RAW est utilis?
    ? D?clenchement possible avec ou sans carte m?moire
    ? R?glage FEC (Flash Exposure Compensation ? Compensation d'exposition du flash) par le bouton JUMP. Utilisation de la molette pour effectuer le r?glage, visible sur l'?cran LCD. Possible seulement en modes cr?atifs.
    ? ISO 3200 disponible, repr?sent? par un "H" sur l'?cran LCD
    ? Mirror Lockup (blocage mirroir) disponible en activant l'option correspondante dans les fonctions personnalis?es. A pour effet de relever le mirroir ? l'appui sur le bouton de d?clenchement. Le rideau s'ouvre alors apr?s le temps sp?cifi? dans la fonction personnalis?e 17
    ? Temps entre relevage du mirroir et ouverture du rideau ajustable via la fonction personnalis?e 17. Les temps possibles sont : 1,5s, 3s, 4.5s, 6s, 7.5s et 10s
    ? Apr?s la prise d'une photo, l'appui sur le bouton ERASE efface imm?diatement la photo prise.
    ? En modes cr?atifs, le bouton directionnel gauche modifie le mode de mise au point. Celui-ci est alors affich? sur l'?cran LCD de la mani?re suivante :
    o AF OF : MAP (mise au point) manuelle
    o AF OS : One Shot
    o AF SE : AI-Servo (s?lectionnable, mais le d?clenchement ne fonctionne pas)
    o AF AI : AI-Focus (prend d'abord une photo puis l'appareil peut basculer en mode AI-Servo selon le sujet sur lequel la mise au point est faite)
    Nouvelles fonctions apport?es par "UnDutchables 0.1.0 firmware"
    ? Mode rafale en mode de base (modes programmes)
    ? Mode RAW disponible en mode de base (modes programmes). A d?finir en modes cr?atifs au pr?alable.
    ? Choix balance des blancs en mode de base (modes programmes)
    ? Fonction personnalisable n?1 disponible en mode de base, permettant :
    o Choix du niveau de qualit? JPG via le bouton SET
    o Choix param?tres via le bouton SET
    o Menu via le boutton SET
    o Lecture derni?re photo via le bouton SET
    ? Bracketing balance des blancs disponible en mode de base. Mais doit ?tre d?fini en modes cr?atifs (sinon plantage).
    Membre Avatar de david
    août 2004
    Limoges
    Canon 6D : 40D :
    c'est bizard je peus declancher sans crate avec le firmware d'origine
    avril 2004
    Originally posted by tetrapack+Vendredi 18 F&eacute;vrier 2005 11:56--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (tetrapack @ Vendredi 18 F&eacute;vrier 2005 11:56)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-TransFXB@Vendredi 18 F?vrier 2005 11:37
    pour le dutch, je ne sais pas. Et les fonctionnalit?s apport?es (principalement dans les modes programmes, que j&#39;utilise peu) ne semblent pas justifier sont utilisation, pour l&#39;instant.
    la bonne nouvelle en fait c&#39;est que quelqu&#39;un s&#39;interesse encore ? modifier ce logiciel du 300D :
    - possibilit? de forcer l&#39;AF en suivi,
    - possibilit? de forcer le mode d&#39;expo.
    Tetra [/b][/quote]
    Je suis aussi de cet avis. Et il y aura pt?te d&#39;autres petites ?volutions...
    Membre Avatar de Jacques
    février 2005
    Mettet Belgique
    30d-7d
    EF70-200 f/4 USM - EF100-400mm f/4.5-5.6L IS USM - Canon Flash Speedlite 580EX
    Bonjour les ami(e)s
    Ma question va vous para?tre naive mais je suis un "bleu" en la mati?re.
    Si pour une raison de sav je devrait remettre l&#39;original je peux savoir ou le trouver ?
    Merci d&#39;avance
    Amiti?s
    Jacques :blink:
    avril 2004
    Originally posted by Jacques@Vendredi 18 F?vrier 2005 19:05
    Bonjour les ami(e)s
    Merci d&#39;avance
    Amiti?s
    Jacques :blink:
    Oui, il est dispo sur le site officiel de canon je pense.
    Edit : Zut grill?
    Membre Avatar de didier31
    novembre 2004
    31 Haute-Garonne
    il est LA
    février 2005
    Mettet Belgique
    30d-7d
    Merci &#33;
    avril 2004
    ?a y est je viens de mettre le firmware russe... apr?s un an avec celui d&#39;origine... c un peu comme un nouveau jouet, en tout cas j&#39;ai pri?.
    S.
    juin 2004
    Lyon - Rhône -69
    EOS 20D et 40D
    Bravo sakana.
    Je pense que tu ne seras pas d??u par les fonctionnalit? suppl?mentaires.
    TransFXB
  32. #32
    Oui David ave le firmware d&#39;origine tu peux d?clencher sans carte c&#39;est pas bizzare c&#39;est comme cela
    gokart regarde ici :
    https://www.eos-numerique.com/forum/...?showtopic=811
  33. #33
    février 2005
    Cannes
    5D + 300 D
    Merci pour le lien.
    Bon, si je comprends bien le mode AI FOCUS AF c&#39;est comme le mode AI SERVO sauf qu&#39;il faut appuyer ? moiti? sur le d?clencheur pour obtenir la mise au point continue... Et en mode AI SERVO , la mise au point continue est activ?e tout le temps sans avoir ? appuyer sur le d?clencheur...
    J&#39;ai bon ?? :unsure:
    ...&#39;Sont compliqu?s chez Canon... :blink:
  34. #34
    décembre 2004
    Beaujolais
    Non, le mode focus AI c&#39;est comme le mode One Shot sauf que quand tu recadres ton sujet apr?s avoir effectu? la mise au point ou que tu souhaites parfaire ta mise au point avec la bague d&#39;un objectif USM, le moteur se met ? p?daler pour te sacager ton focus que tu as mis du temps ? faire correctement car l&#39;appareil pense que ton sujet ? boug? et il passe en AI servo. C&#39;est le genre de progr?s dont on se passerait bien et qui est vraiment gavant, surtout qu&#39;on ne peut pas le d?sactiver avec le firmware d&#39;origine.
  35. #35
    Utilisateur
    décembre 2004
    WB-Bracketing
    Notes:
    en gras => cela sous-entends que l&#39;AIservo fonctionne maintenant ? il n&#39;y a plus la mention "dosen&#39;t work" et le 2) d?tail le fonctionnement....
    d&#39;autre part le lien donn? au debut du topic pour le telecharger ne fonctionne plus; Savez-vous ou l&#39;on peut se procurer cette nouvelle version ?
    EDIT : J&#39;ai trouv? le fichier et j&#39;ai eu la confirmation que l&#39;AI servo n&#39;est toujours pas operationnel
  36. #36
    excusez moi de poser une question con mais...
    ? koi ?a sert ces firmwares ???
    c&#39;est une sorte de mise ? jour de l&#39;appareil ???
  37. #37
    décembre 2004
    Beaujolais
    Un firmware est une sorte de syst?me d&#39;exploitation de l&#39;appareil, un genre de BIOS avec une couche logicielle qui permet de piloter tous les composants. Le firmware contient notamment le noyau de traitement de l&#39;image pour la transformer en jpeg en fonction des param?tres choisis par l&#39;utilisateur (balance des blancs, saturation, sharpness, etc...). Dans le cas du 300D le firmware est tr?s proche de celui du 10D mais il contient des bridages volontaires de la part de Canon pour limiter volontairement les possibilit?s de l&#39;appareil. Certains ont r?ussi ? faire sauter ces verrous mais pas tous (sans compter que certains sont hardware et ne peuvent pas ?tre ?t?s sans modification du mat?riel).
  38. #38
    avril 2004
    Rien que pour pouvoir shooter en fullquality RAW je suis heureux de l'avoir install? !
    S.
  39. #39
    Membre Avatar de spike_fr
    décembre 2004
    TroissantDé, TranteDé, CinqDéMarkDe
    Objo Canon & Tamron
    Citation Envoyé par TransFXB
    o AF OS : One Shot
    D'apr?s ce que je sais, la mise au point se fait grace aux points rouges que l'on voit dans le viseur ...
    Est-ce que quelqu'un pourrai expliquer ces diffents modes svp ?
  1. Nouveau Firmware 2.03 pour le 20D
    Par nuts94 dans le forum Canon
    Réponses: 49
    Dernier message: 22/01/2006, 19h57
  2. Nouveau Firmware 2.02 pour 20D
    Par JMG dans le forum Canon
    Réponses: 66
    Dernier message: 14/01/2006, 03h10
  3. Nouveau Firmware 1.1.0 pour le 20D
    Réponses: 66
    Dernier message: 25/08/2005, 09h03
  4. Nouveau Firmware 2.0.0 pour le 20D
    Réponses: 59
    Dernier message: 25/07/2005, 10h23
Fuseau horaire GMT +1. Il est actuellement 11h11.
