15/01/2017, 11h53 #1Membre
- septembre 2007
- Moxhe - Belgique
- 65
- 1 191
- EOS 6D MkII
- Sigma 105mm F2.8 EX DG Macro OS / tamron 150-600 mm sp f/5-6.3 di vc usd g2
EOS 60D / EOS 60Da Firmware Update, Version 1.1.2 [Windows ][Mac OS X]
Juste pour ceux que cela intéresse il y a une mise a jour du Firmware pour le 60D /60Da
EOS 60D Support ? Download drivers, software & manuals
Firmware Version 1.1.2 incorporates the following fix:
Corrects a phenomenon in which when using the camera with the EF-S 18-135mm f/3.5-5.6 IS USM or EF 70-300mm f/4-5.6 IS II USM lens, even if lens aberration correction is set to ""Enable"", correction will not be applied.
Firmware Version 1.1.2 is for cameras with firmware up to Version 1.1.1. If the camera's firmware is already Version 1.1.2, it is not necessary to update the firmware.
When updating the firmware of the camera, please review the instructions thoroughly before you download the firmware.
aide installation firmware 2.0.3 eos 7d sous windows( compact flash)
Par nicky3007 dans le forum CanonRéponses: 11Dernier message: 07/08/2013, 20h26 -
EOS 350D DIGITAL Firmware Update Version 1.0.3 ( Octobre 2005)
Par DJEZZ dans le forum CanonRéponses: 3Dernier message: 15/06/2013, 15h15 -
Firmware update program
Par Auna dans le forum CanonRéponses: 7Dernier message: 24/11/2011, 15h03 -
colorsync version windows
Par belnea dans le forum Les Logiciels photoRéponses: 3Dernier message: 12/09/2007, 14h53 -
20D... update firmware? Késako?
Par loorent dans le forum CanonRéponses: 2Dernier message: 19/05/2006, 16h09
