    Membre Avatar de YVES42
    FRANCE
    7D + Grip
    15-85 IS USM + 70-200 F4 L IS+ 50 f1.4
    Par défaut Filigrane incrementale
    Bonjour.
    Je souhaite avoir un script qui inscrive un numéro incrémentale en bas de ma photo et qui l'enregistre sous le numero + le nom d'origine.
    En cherchant sur le net j'ai trouvé ceci :
    Code:
    // vous utilisez ce script à vos propres risques !
    #target photoshop
    // folder selection;
    var theFolder = Folder.selectDialog ("select folder");
    if (theFolder) {
       var theFolderFiles = retrieveTIFandPSDandJPG (theFolder, []);
       var originalRulerUnits = preferences.rulerUnits;
       preferences.rulerUnits = Units.PERCENT;
    // work through the files;
       for (var m = 0; m < theFolderFiles.length; m++) {
          var theNumber = bufferNumberWithZeros(m + 1, 3);
          var myDocument = app.open(File(theFolderFiles[m]));
    // getting the name and location;
          var docName = myDocument.name;
          var basename = docName.match(/(.*)\.[^\.]+$/)[1];
    //getting the location;
          var docPath = myDocument.path;
    // create a text layer;
          var textLayer = myDocument.artLayers.add();
          textLayer.kind = LayerKind.TEXT;
          textLayer.name = "text";
          textLayer.blendMode = BlendMode.NORMAL;
          textLayer.opacity = 100;
          var myTextRef = textLayer.textItem;
          myTextRef.size = 150;
          myTextRef.font = "Arial";
          var newColor = new SolidColor();
          newColor.rgb.red = 255;
          newColor.rgb.green = 255;
          newColor.rgb.blue = 255;
          myTextRef.color = newColor;
          myTextRef.position = new Array( 1, 99);
          myTextRef.contents = theNumber;
    // jpg options;
          var jpegOptions = new JPEGSaveOptions();
          jpegOptions.quality = 12;
          jpegOptions.embedColorProfile = true;
    //save jpg;
          myDocument.saveAs((new File(docPath+"/"+theNumber+"_"+basename+".jpg")),jpegOptions,true);
          myDocument.close(SaveOptions.DONOTSAVECHANGES)
       preferences.rulerUnits = originalRulerUnits;
    ////// get tif-, psd-, jpg-files from folder and subfolders //////
    function retrieveTIFandPSDandJPG (theFolder, theFiles) {
       if (!theFiles) {var theFiles = []};
       var theContent = theFolder.getFiles();
       for (var n = 0; n < theContent.length; n++) {
          var theObject = theContent[n];
          if (theObject.constructor.name == "Folder") {
             theFiles = retrieveTIFandPSDandJPG(theObject, theFiles)
          if (theObject.name.slice(-4) == ".tif" || theObject.name.slice(-4) == ".psd" || theObject.name.slice(-4) == ".jpg") {
             theFiles = theFiles.concat(theObject)
       return theFiles
    ////// buffer number with zeros //////
    function bufferNumberWithZeros (number, places) {
       var theNumberString = String(number);
       for (var o = 0; o < (places - String(number).length); o++) {
          theNumberString = String("0" + theNumberString)
       return theNumberString
    Cela fonctionne assez bien mais je souhaiterai choisir le numéro de départ de la numérotation.
    Avez vous une idée ?
    Merci pour votre aide
    Membre Avatar de antec
    septembre 2013
    France (08)
    Eos 70D
    Canon + ...
    novembre 2013
    IdF (77)
    5D4,5D3,6D2,7D
    La variable gérant le numéro c'est "theNumber" sa valeur dépend de "m" qui est initialisé dans la boucle for à 0
    Bonne continuation
    FRANCE
    7D + Grip
    Bonjour Antec
    Oui c'est ceci mais je veux rester sur un script ( gratuit )
    je voulais éviter de passé par une appli supplementaire.
    Bonjour YVnod77
    j'avais compris que la valeur thenumber contrôlais le numero mais je ne veux pas a avoir a modifier le code pour chaque utilisation.
    Je pensais qu'il était possible d'avoir une boite de dialogue qui demande le numero de depart.
    J'ai fais des essais mais le contenu de ma boite de dialogue est considéré comme du texte
    exemple si je rentre 100
    l’incrémentation se fait 100 1 - 100 2 - 100 3 - 100 4
    voici mon essai :
    Code:
    #target photoshop
    if (theFolder) {
     var reponse = prompt("Numero de la première photo ?", "<Entrez ici votre numero>");
    if( reponse == null ){
        alert("Vous avez cliqué sur Annuler");
    } else
     var r = reponse;
               var theNumber = bufferNumberWithZeros(r+ m, 3);
    // jpg options;
    //save jpg;
       return theFiles
    novembre 2013
    IdF (77)
    5D4,5D3,6D2,7D
    Je pense que c'est un problème de typage de variable (ou de transtypage, conversion de type)
    r et reponse doivent être de type chaine de caractères, m est de type entier, la fonction bufferNumberWithZeros attend un entier "number" et un entier "places"
    Je te propose plusieurs tests :
    - Retires l'espace devant le m dans l'appel "var theNumber = bufferNumberWithZeros(r+m, 3);"
    - Utilises une variable dans l'appel de fonction "var toto = m+r ;" l'appel devient "var theNumber = bufferNumberWithZeros(toto, 3);"
    - essaies quelque chose du genre "var r = 0+reponse;" a la place de "var r = reponse;"
    - recherches une fonction qui convertisse les chaines de caractères en entier (en gros l'inverse de la fonction string utilisé dans la fonction bufferNumberWithZeros, peut être Int ou Integer ?
    FRANCE
    7D + Grip
    Merci pour tes conseils.
    c 'est effectivement un problème de type de variable
    J'ai trouvé j'ai rajouté un : parseInt et cela fonctionne.
    Le script fonctionne mais quelquefois il ne s 'exécute pas complètement.
    Photoshop se lance
    la fenêtre dossier aussi
    la boite de dialogue pour le chiffre de départ aussi
    et puis au moment du traitement des photos plus rien.
    Le problème peut il venir du poids ou de la résolution des photos cela arrive qu'une fois de temps en temps
  1. Filigrane sous LR 3.6
    Par Golgoth XII° dans le forum Lightroom
    Dernier message: 17/08/2014, 22h33
  2. filigrane de ronce
    Par dkeith dans le forum [Noir & Blanc]
    Dernier message: 20/10/2011, 14h58
  3. Filigrane or not ...
    Par Michel_R dans le forum Discussions générales
    Dernier message: 04/06/2010, 23h54
  4. filigrane et Lightroom
    Par chacha95 dans le forum Lightroom
    Dernier message: 26/01/2009, 02h28
  5. Filigrane
    Par gribou dans le forum Les Logiciels photo
    Dernier message: 03/05/2007, 17h21
Fuseau horaire GMT +1. Il est actuellement 11h39.
