    Membre Avatar de luc56
    St Armel Morbihan
    7D, 40D, SX10IS
    Par défaut UFRaw gimp fichier raw eos 400d pour linux
    Pour information et en avant premiere j'ai modifie UFraw et le plugins son GIMP pour decoder les fichier RAW des Canons EOS 400D
    le tgz du code est sur le site suivant
    http://velo-sport-de-rhuys.chez-alice.fr/ufraw-0.9.1.modif.tgz
    Le site officiel de UFraw
    http://ufraw.sourceforge.net
    et la procedure d'installation :
    recupere le fichier ufraw-0.9.1.modif.tgz
    tar xzf ufraw-0.9.1.modif.tgz
    cd ufraw-0.9.1.01
    ./configure
    make
    make install-user
    plus d'explication sur l'installation sur le site UFRAW:
    Now, you can download the UFRaw tarball ufraw-0.9.1.tar.gz, extract the files from it and enter the ufraw-0.9.1 directory:
    cd ufraw-0.9.1.01
    Next, you should run the configuration script:
    ./configure
    You will get a long output and at the end there will be a summary that should look approximately like:
    configure: ====================== summary =====================
    configure: build gimp plug-in: yes
    configure: hidden directories support (GTK>=2.6): yes
    configure: EXIF support using libexif: no
    configure: EXIF support using exiv2: no
    configure: JPEG support: yes
    configure: TIFF support: yes
    configure: TIFF deflate (lossless compression) support: yes
    There are also UFRaw specific flags for configure:
    --disable-gimp - disable build of the gimp plug-in
    --enable-extras - build extra (dcraw, nikon-curve) executables
    --with-libexif - use libexif to read raw EXIF data
    --with-exiv2 - use exiv2 to read raw EXIF data
    --with-prefix=PREFIX - use also PREFIX as an input prefix for the build
    --with-dosprefix=PREFIX - PREFIX in the the prefix in dos format (needed only in windows)
    Next, you should build UFRaw by typing the command:
    make
    For installing the UFRaw Gimp plug-in, you have two options. You can install it only for the current user, which does not require root privileges, but only the current user will see the plug-in
    make install-user
    or you can make a system wide installation (requires root privileges)
    make install
    This will also install the stand-alone tools ufraw, ufraw-batch and some related files (man page, icon and desktop definitions).
    Membre Avatar de syn
    Rennes
    Kenko EF 10-300 1.8 IS USM
    Bonne initiative, au cas où tu peux soumettre ta modif à l'auteur de façon à l'inclure dans la distribution officielle (si pas déjà fait )
    juin 2006
    toulouse
    canon eos 33
    Au fait, j'ai découvert ce tutorial très bien fait (assez récent?) sur UFraw, qui répond à pas mal de questions que je me posais. Et en plus c'est en français!
    http://gimp-fr.org/document/document_22/
    Bonne lecture,
    RB
    eos 400D
    avant d'aller plus loin, pouvez-vous me dire comment faire pour monter mon eos 400d sur linux?
    Merci d'avance pour votre aide.
    Rennes
    Salut nauw,
    tu ne peux pas le monter en tant que stockage de masse.
    Pour récupérer tes photos, tu peux utiliser gtkam ou digikam sous kde, f-spot ou gthum sous gnome.
    Seul gthumb ne permet pas d'importer les .cr2 .
    Membre Avatar de Blue
    Loire Atlantique
    18 à 400 mm
    C'est juste sous Nux ou c'est compatible crosoft ??
    Rennes
    Citation Envoyé par Blue Voir le message
    De qui de quoi? Ta question n'est pas très claire!
    Sachant que ce fil concerne plutôt Linux, à toi de voir :p
    Loire Atlantique
    18 à 400 mm
    Citation Envoyé par syn Voir le message
    promis je vais lire les titres :fear(1):
    Membre Avatar de spike_fr
    décembre 2004
    TroissantDé, TranteDé, CinqDéMarkDe
    Objo Canon & Tamron
    Ben mince alors !
    et vous savez si on peut installer linux sur un 30D aussi ??
    ... ok je sort ! :bash:
    eos 400D
    Super!!!
    En fait l'erreur venait des droits d'accès sur le port, en root, pas de problème ça se monte.
    C'est vraiment un super appareil... en plus il fonctionne bien sous GNU-Linux, que demande le peuple!!!?
    Merci pour les infos.
    St Armel Morbihan
    7D, 40D, SX10IS
    Par défaut cinepaint 400D
    Si ca interesse quelqu'un, j'ai aussi modifie un fichier dans les sources de cinepaint
    pour convertir des raw du 400D
    L'avantage de cinepaint sur gimp est qu'il travaille en 16 bits par couleur
    cinepaint est un evolution de gimp ....
    luc
    Loire Atlantique
    18 à 400 mm
    Mais sinon sous crosoft vous auriez pas la même chose ........
    Pour le 400D biensur
    Dernière modification par Blue ; 20/10/2006 à 12h54.
    Rennes
    La plupart des logiciels de traitement des fichiers raw se sont mis au goût du jour et prennent en charge les fichiers raw du 400D ... dpp, lightroom, bibble, camera raw, et j'en passe certainement..
  1. Light Zone pour Linux
    Par kagou dans le forum Les Logiciels photo
    Réponses: 18
    Dernier message: 13/04/2008, 06h54
  2. Dcraw et Ufraw pour 40d
    Par luc56 dans le forum Les Logiciels photo
    Dernier message: 07/10/2007, 15h53
  3. DCRAW/UFRAW pour Gutsy
    Dernier message: 06/09/2007, 20h50
  4. Numération des fichier - 400D
    Par pomodoro dans le forum Discussions techniques
    Dernier message: 02/04/2007, 11h48
  5. 400D : Pas de Fichier RAW ?!
    Par labestyle dans le forum Discussions techniques
    Dernier message: 19/02/2007, 02h48
Fuseau horaire GMT +1. Il est actuellement 16h11.
