    Membre Avatar de macgreeny
    octobre 2009
    Bretagne
    500D
    Canon 50 f1.8, 18-55
    Exclamation Firmware 2.0.4 pour EOS 5D Mark II
    Canon EOS 5D Mark II Firmware Update
    EOS 5D Mark II Firmware Update Version 2.0.4
    Firmware changes
    In the Version 2.0.4 firmware, the following phenomena that occurred with the Version 2.0.3 firmware (which was to enhance the movie functions) have been corrected.
    There was a phenomenon in which the manual recording settings made in C1/C2/C3 were changed and sound could not be recorded if manual sound recording was used in the C1/C2/C3 settings and the camera was subsequently turned off (or if Auto Power Off was activated). This does not occur in modes other than C1/C2/C3.
    The Version 2.0.4 firmware includes the movie function enhancements listed in items 1 through 5 below, and also incorporates the correction listed in item 6.
    Adds or changes the following movie frame rates.
    NTSC:
    1920×1080 : 30 fps (changed - actual 29.97 fps)
    1920×1080 : 24 fps (added - actual 23.976 fps)
    640×480 : 30 fps (changed - actual 29.97 fps)
    PAL:
    1920×1080 : 25 fps (added - actual 25.0 fps)
    640×480 : 25 fps (added - actual 25.0 fps)
    Adds a function for manually adjusting the sound recording level (64 levels).
    Adds a histogram display (brightness or RGB) for shooting movies in manual exposure.
    Adds shutter-priority AE mode (Tv) and aperture-priority AE (Av) mode to the exposure modes for shooting movies.
    Changes the audio sampling frequency from 44.1 KHz to 48 KHz.
    Fixes a phenomenon where communication between the camera and the attached lens is sometimes interrupted after manual sensor cleaning. (This phenomenon only affects units with Firmware Version 1.2.4.)
    Caution:
    Firmware Version 2.0.4 is for cameras with firmware up to version 2.0.3. If the camera's firmware is already version 2.0.4, it is not necessary to update the firmware.
    Movies captured using EOS 5D Mark II cameras with Firmware Version 1.1.0 to 1.2.4 can be played back on cameras updated with Firmware Version 2.0.4. However, if you try to play back movies captured with a camera with the new firmare on a camera with a previous firmare version, a message, Cannot play back image, appears on the camera's LCD monitor.
    It is recommended that you use the latest Canon applications*1 to edit movies captured with EOS 5D Mark II cameras that have the latest firmare because some previous versions do not support movie-editing functions and the frame rates that are added or changed by the latest firmware. You can download the latest Canon applications from our Web site.
    *1 ZoomBrowser EX Version 6.5.0 or later (compatible operating systems : Windows XP/Vista/7)
    ImageBrowser Version 6.5.0 or later (compatible operating systems : Mac OS X v10.4/10.5/10.6)
    In addition to the enhancements to the movie function, the accompanying instruction manual has also been revised. Users are asked to download both the latest firmware and the latest instruction manual. You can proceed to download the instruction manual by
    FRANCE
    EOS D30
    EF 28-80
    On a attendu longtemps la 2.03, maintenant on va en avoir un toutes les semaines :clap_1:
    EOS 5D MkII
    24-70/2.8 USM et 70-200/2.8 IS USM
    Ca n'a pas trainé,
    clap_1::clap_1:
    Maintenant, c'est assez surprenant de voir une mise à jour tant attendue avec un Bug.
    Ils ne testent pas leurs mise à jour Canon ????
    :34::34:
    Membre Avatar de icna99a
    5D Mark II, EOS M
    22, 40, 50, 100 macro, 17-40, 18-55, 24-105, 28-135, 70-200, doubleur, 580 EX II
    peut être qu'ils n'utilisent pas les modes C1, C2, C3 ...comme moi quoi :rudolph:
    mars 2009
    Belgique - Ruisbroek (Uccle )
    1Ds MkII + 5D MkII + 7D MkII
    Moi j'aurai bien apprécié qu'ils ajoutent surtout le mode HD Ready 1366x720P @ 30/25/24fps mais bon j'espère qu'ils y penseront
    Canon EOS5D
    24-105 / 17-40 / 70-200
    Citation Envoyé par IzNoGood Voir le message
    Plutôt le 1280 X 720 non
    Arpège
    Membre Avatar de resche
    france
    EOS 5 D+Mk2 & 1DMk2+3
    12/24-24/70-70/200-400-100macro-MPE65 f2,8
    Par défaut magnifique firmware
    Bon, je pensais que seuls les rideaux de nos appareils made in Japan étaient fabriqués en Chine. Voilà que Canon, vient de leur confier le développement des firmwares.
    ... Canon, il faut qu'on t'aime beaucoup pour accepter autant d'étourderies, mais n'en abuse pas trop !!.
    Membre Avatar de baron_noir
    Sainte Eulalie (33)
    5D MK III
    Des cailloux, dans les choux, pour les hi bouts de ficelle en plus
    Mais pourquoi donc ne retrouve t-on pas la mise à jour d'un firm pour le 5Dmk2 dans la base EOS ?
    ce modele est-il bani et mis au rancard car déja obsolete c'est le mkk !
    Vivement le 5D mk3
    Citation Envoyé par baron_noir Voir le message
    Vivement le 5D mk3
    Tout vient à point pour qui sait attendre.
    Abonné Avatar de lbuisson
    OISE-60
    Sony A9 / CANON G15 et AE-1
    hop mise à jour effectuée
    Membre Avatar de davidemb
    EOS 30, 430 EX II, 6D
    135L, 100L, 24-105L, 85 F1.8 et sigma 35 F1.4 (et 17-40 malade car grosse chute...)
    J'ai même pas encore fait la MAJ 2.0.3, faut la faire avant celle-ci, on ne peut pas passer directement à la 2.0.4?
    Citation Envoyé par davidemb Voir le message
    Tu passes direct : je suis passé d'une version 1 à la version 2, aucun problème
    OISE-60
    idem
    Ok merci de l'info Jean et Laurent
    france
    eos 5D mkII
    35/2 et 85/1,8
    bonjour,
    je ne vois que des versions anglaises???
    Comment télécharger ce firmware avec un Mac?J'ai sur le mien la version 1,2,4
    Merci de votre aide.
    Membre Avatar de spike_fr
    décembre 2004
    TroissantDé, TranteDé, CinqDéMarkDe
    Objo Canon & Tamron
    Et....en ce qui concerne le fameux bug de la 2.0.4 ...
    Personne n'a eu ce souci ???
    Nouvel utilisateur
    novembre 2013
    5D mk ii
    lots !
    Bonjour voici une question un peu con surement, ou passéiste et je vous le concède, mais neanmoins urgente ! Je dois filmer un cheval pour un clip en "slow motion" j'utilise twixtor pour l'effet avec mes rushs 5D Mark ii. Je pense que passer en 30 fps serait une bonne idée pour un meilleur rendu. PROBLEME ! Canon ne propose cette vieille MAJ nulle part !
    Je suis donc à la recherche d'un downgrade vers le firmware du 5D M ii 2.0.4. Mac OSx qui permettais la capture en 30fps.
    Je suis actuellement sur la derniere version du firmaware, et de Magic Lantern et je ne vois AUCUNE solution à ce jour ! Avez vous soit une idée pour soit :
    -Pouvoir downgrader sur 2.0.4 (à savoir que le lien de canon est inactif)
    -Une solution me permettant de filmer avec le 5D Mark ii en 30 fps (ou plus ?!)
  1. Nouveau firmware 2.0.3 pour EOS 5D Mark II
    Par macgreeny dans le forum Canon
    Réponses: 64
    Dernier message: 21/03/2010, 07h49
  2. soucis firmware 1.1.2 pour 1d mark II N
    Par solian400 dans le forum Canon
    Dernier message: 16/04/2009, 13h55
  3. EOS 1DS MARK III - Firmware 1.0.6
    Par dufour_l dans le forum Canon
    Dernier message: 07/01/2008, 09h08
  4. Firmware 1.1.0 pour le Mark III
    Par Zorg44 dans le forum Canon
    Réponses: 24
    Dernier message: 29/09/2007, 12h30
  5. Nouveau firmware pour le Canon EOS-1D Mark III
    Dernier message: 30/07/2007, 22h07
Fuseau horaire GMT +1. Il est actuellement 20h15.
