Discussion: Spec 20D
    Membre Avatar de ArchY
    mai 2004
    Saint Germain en Laye, France
    EOS 300D
    fed
    http://www.sdcard.be/Nederlands/store/view...product=8979348
    Item Includes
    EOS-20D Body, EF-s 17-85mm f4-5.6 IS lens, Eyecup Eb, Camera Cover R-F-3, Neck Strap EW-100DB, Video Cable VC-100, Interface Cable IFC-300PCU, Battery BP-511, Battery Charger CB-5L, EOS Digital Solution Disk Version 6.0, Photoshop Elements 2.0, Quick Operation Guide, Instructions
    Description
    A 8.2 Megapixel Canon CMOS sensor delivers superbly detailed images. 9-point high-speed AF allows precise focusing over a wide area. A powerful DIGIC II(DIGital Imaging Core) processor optimises colour rendition. High speed processing means a continuous burst of 5 shots at 25 frames per second is possible. It also extends the camera's battery life. The EOS 20D can write RAW and JPEG files simultaneously, while there's a choice of 6 JPEG resolution settings.
    For enhanced exposure stability, the EOS 20D has a new evaluative metering system for both daylight and flash. As well as sRGB, the EOS 20D features Adobe RGB. This improves colour rendition by capturing colours across an extremely wide spectrum. An ISO speed range from 100 - 1600 (3200 Extended HI accessible via the ISO expansion menu) offers extensive shooting flexibility whatever the lighting conditions.
    9 white balance modes are available - Auto, Daylight, Shade, Cloudy, Tungsten, Flourescent, Flash, Custom and Colour Temperature. In Colour Temperature mode, users manually select the warmth they require from the Kelvin scale (2800K to 10000K in 100K increments). With White Balance Bracketing, the EOS 10D automatically captures three bracketed shots (normal, reddish and bluish) with one release of the shutter.
    An Intelligent Orientation Sensor detects whether the camera is being held horizontally or vertically when shooting. This gives mor e accurate exposures. It also means easy viewing and editing, since shots appear the right way up on the LCD, in ZoomBrowser on the computer screen or on TV.
    The EOS 20D's LCD offers 5 levels of brightness. It can be brightened so it's easier to see or dimmed so it's less intrusive and saves power. The menu display offers the choice of 12 different languages.
    With a robust magnesium alloy body, the EOS 10D has outstanding durability and a distinctive presence. It features an ergonomic hand-grip which makes extended shooting very comfortable.
    The EOS 20D is the fourth digital EOS camera to feature Direct Print. High resolution prints can be obtained by connecting straight to a Canon Bubble Jet or Card Photo Printer. The EOS 20D has FAT 16/32 data storage, allowing compatibility with high capacity CF cards over 2GB. The EOS 20D is compatible with the extensive EOS range of accessories.
    Features
    8.2 Megapixel CMOS sensor
    DIGIC II processor
    Wide area 9-point AF
    5 fps shooting
    35 zone evaluative metering
    Simultaneous RAW and JPEG processing
    Durable EOS magnesium body
    Wide ISO speed range up to ISO H3200
    Expanded image display zoom options
    Specifications
    Image Sensor High-sensitivity, high-resolution, large 22.7 x 15.1mm single-plate CMOS sensor.
    Total pixels: Approx. 8.20 megapixels (Effective pixels: Approx. 8.2 megapixels)
    Color Filter System: RGB primary color filter
    Low-Pass Filter: Located in front of the image sensor, non-removable
    Lens Mount Canon EF mount
    LCD monitor/LCD Info 1.8" TFT Color Monitor (Approx. 118,000 Pixels)
    Viewfinder Eye-Level Type
    Fixed, New Laser Matte screen Focusing screen
    Viewfinder Information: AF, Exposure, Flash, Warnings maximum burst for continuous shooting, shots remaining Depth-of-field preview: Enabled with depth-of-field preview button
    Focal lengh multiplier 35mm-equivalent focal length is equal to approx.1.6 times the marked focal length.
    Focusing Type 9 point AF, TTL-CT-SIR (TTL secondary phase difference detection)
    Focus Modes One-Shot AF, AI Servo AF, AI Focus AF, Manual focusing (MF)
    Sensitivity (ISO equiv film speed) Equivalent to ISO 100, 200, 400, 800, 1600, and ISO 3200 with ISO speed extension
    White balance Auto, daylight, shade, cloudy, tungsten light, fluorescent light, flash, manual, color temperature setting
    Exposure Modes Program AE (Full Auto, Portrait, Landscape, Close-up, Sports, Night Portrait, Flash Off, Program), shutter-priority AE, aperture-priority AE, depth-of-field AE, manual exposure, ETTL autoflash
    Exposure Metering TTL full aperture metering with 35-zone SPC,
    (1) Evaluative metering, (2) Partial metering at center (approx. 9% of viewfinder), (3) Centerweighted average metering
    Metering Range: EV 1-20 (at 20?C with 50mm f/1.4 lens, ISO 100)
    Exposure Compensation 1) AEB (Auto Exposure Bracketing) +/- 2 stops in 1/2- or 1/3-stop increments (can be combined with AEB)
    2) Manual exposure compensation
    3) Flash exposure compensation
    Shutter type Electronically-controlled focal-plane shutter
    Shutter Speed Shutter speeds: 1/8000 - 30 sec. (1/2- or 1/3-stop increments), bulb, X-sync at 1/200 sec.
    Mirror Quick-return half mirror (Transmission: reflection ratio of 40:60 (no mirror cut-off with EF 600mm f4 or shorter lens)
    Diopter Correction -3.0 - +1.0 diopter
    Built-In Flash Auto pop-up E-TTL autoflash (retractable
    Guide No 13 (ISO 100, meters), 43 (ISO 100, ft.)
    Recycling time Approx. 3 sec.
    Flash coverage 18mm lens angle covered
    Flash exposure compensation +/-2 stops in 1/2- and 1/3-stop increments
    External Flash Sync (1) Hot shoe: X-sync contacts E-TTL II autoflash set with EX-series Speedlites
    PC terminal Provided
    Video Out NTSC and PAL
    Interface USB
    Burst rate Approx. 5 fps (at 1/250 sec. or faster shutter speed) up to 9 shots
    Video mode none
    Audio annotation none
    Internal Memory/Memory card CompactFlash Card (Type I & II), Microdrive
    File Size 1) Large/Fine: approx. 2.4MB (3072x2048 pixels)
    2) Large/Normal: approx. 1.3MB (3072x2048 pixels)
    3) Middle/Fine: approx. 1.4MB (2048x1360 pixels)
    4) Middle/Normal: approx. 0.7MB (2048x1360 pixels)
    5) Small/Fine: approx. 0.9MB (1536x1024 pixels)
    6) Small/Normal: approx. 0.5MB (1536x1024 pixels)
    7) RAW: approx. 8.2MB (3072x2048 pixels)
    Image modes JPEG (EXIF 2.2/EXIF print compliant). RAW or Both.
    Self Timer Electronically-controlled 10-sec. Delay
    Remote Control N3-type terminal
    Depth of Field Preview Enabled with depth-of-field preview button
    Power Source One Battery Pack BP-511/BP512 (lithium ion rechargeable battery)
    Back-up battery CR2025; One lithium battery
    Dimensions 149.7 (W) x 107.5 (H) x 75 (D) mm /5.9 (W) x 4.2 (H) x 3.0 (D) in.
    Weight 740 g / 26.1 oz. (Excluding the Battery Pack, Compact Flash card and back-up battery.)
    System requirements Windows 98SE, 2000, ME, XP;
    Mac OS 8.6-9.x, OS X (10.1)
    Special features 12 LCD monitor languages,
    Custom Functions 17 Custom Functions with 61 settings
    Prijs EUR 2298,00
    Comme je le pensais d?ja hier,le prix annonc? (2300?) sur ce site semble plus logique vu les capacit?s de l'appareil.
    Il faudra maintenant attendre la mise sur le march? de l'appareil pour ?tre fix?... :unsure:
    jasper
    juin 2004
    Asnières
    1D MK III
    24-105/4.0 L IS USM, 70-200/4.0 L IS USM, 85/1.8 USM, 135/2.0 L USM, 300/4.0 L IS ISM
    Le prix a d?j? baiss? :
    Prijs EUR 1998,00
    Geen stock op dit moment
    Et c'est la version kit avec un objectif zoom grande amplitude et IS. Donc pas un truc ? 100 ?.
    On peut donc penser que le 20D nu devrait ?tre aux alentours de 1600-1700 ?.
    avril 2004
    Moselle
    EOS 350D & EOS 600D
    18-55 / 28-90 / 60 2.8 Macro
    Cool ! S'il baisse toute les 2 heures, j'aurais bient?t les 200 ? pour me l'acheter
    LCL2000.
    avril 2004
    Moselle
    EOS 350D & EOS 600D
    C'est marrant, quand on clique sur la photo, il n'y a pas de photo qui s'affiche par contre le lien c'est :
    http://www.sdcard.be/Nederlands/store/catl...&sku=ICA10D.jpg
    On peut voir 10D.jpg.....pourquoi pas 20D.jpg.....
    Ok, je sors
    LCL2000.
    juin 2004
    Asnières
    1D MK III
    Les specs sont un peu revues ? la baisse sur la prise de vue en rafale :
    -Burst rate Approx. 5 fps (at 1/250 sec. or faster shutter speed) up to 9 shots
    Mais c'est d?j? pas mal. Il faut voir combien ?a prend de temps pour transf?rer ces 9 images.
    avril 2004
    Moselle
    EOS 350D & EOS 600D
    Et le 300D c'est combien ?
    LCL2000.
    juin 2004
    Asnières
    1D MK III
    300D :
    2.5 FPS, 4 shots
    10D :
    3 FPS, 9 shots
    1D Mark II :
    8.3 FPS, 40 shots
    Nikon D70 :
    3 FPS 12/15 shots, 2 FPS continuous
    Canon a encore des progr?s ? faire sur la gestion du transfert vers la CF.
    avril 2004
    Moselle
    EOS 350D & EOS 600D
    ouais c'est clair.
    Le 20D se situe bien quand m?me
    LCL2000.
    juin 2004
    Asnières
    1D MK III
    Il fait un poil mieux que le 10D. Mais rien de r?volutionnaire. Je trouve que l'appellation 10D Mark II aurait ?t? plus logique.
    Il y a aussi le Zoom TGA Canon EF 10-22 :
    http://www.sdcard.be/Nederlands/store/view...product=8979363
    498 ?, correct.
    avril 2004
    Moselle
    EOS 350D & EOS 600D
    Originally posted by Puma+--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Puma)</td></tr><tr><td id='QUOTE'>
    [/b]
    Ouais...je regarde surtout par rapport au 300D..
    <!--QuoteBegin-Puma
    Je trouve que l&#39;appellation 10D Mark II aurait ?t? plus logique.
    [/quote]
    Je pense que ?a aurait ?t? logique ?galement....mais la logique se perd
    LCL2000.
    juin 2004
    Asnières
    1D MK III
    C&#39;est clair qu&#39;il y a plus de diff?rences entre le 1D et le 1D Mark II qu&#39;entre le 10D et le 20D.
    Ils font chier avec ces appellations trompeuses.
    Enfin, une fois retomb?e l&#39;excitation de l&#39;annonce surprise, je ne trouve pas le 20D exceptionnel. Le capteur a plus de pixels, mais encore faut-il qu&#39;il soit r?ellement plus performant (bruit, matrice...). De toute fa?on, c&#39;est normal que ?a progresse. Pour le reste, on a le mode E-TTL II qui semble ?tre une correction des faiblesses du E-TTL (? voir sur le terrain) et un flash interne avec un meilleur d?gagement. Et le plus int?ressant pour l&#39;utilisateur, c&#39;est qu&#39;il est "plus rapide" (au d?marrage, obturateur, cadence rafale).
    C&#39;est bien, mais pas transcendant. Pas de pilotage ? l&#39;oeil, pas de transfert rapide vers le PC, pas de nouvelle fonctionnalit?s (genre annotation vocale), toujours le m?me LCD (un peu limite 118000 pixels pour visualiser une image de 8,2 MPixels et aucune protection int?gr?e).
    Bon, ce n&#39;est toujours pas une annonce officielle. Peut-?tre que finalement il y aura des am?lioratons surprises.
    non&#33; appellation 10D markII pour faire un pas en arri?re certainement pas,
    et il faut esp?rer que si 10D markII il doit y avoir ... ce sera un progr?s notable et non pas la marche des crabes dans le d?sert,
    donc le pilotage ? l&#39;oeil , oui mais pas ? n&#39;importe quel prix &#33;
    et des menus programmables ce ne serait pas un luxe &#33;
    pour le capteur celui du 10D est largement suffisant mais si l&#39;escalade se poursuit ce sera probablement un 8Mg, et surtout pas encore une plaisanterie dont canon a le secret avec des bridages quelconques;
    je ne r?le pas &#33;
    je ne dis pas de b?tises&#33;
    ? moins que le fait de dire ce que l&#39;on pense soit devenu d?finitivement interdit,
    un peu d&#39;humilit? et de respect des autres serait un minimum m?me lorsque l&#39;on ? pas les m?mes id?es , bon ce n&#39;est pas donn? ? tout le monde ,
    merci pour m&#39;avoir accueuilli sur votre site, m?me si cela aura ?t? tr?s court mais l&#39;?g?monie c&#39;est une chose que je ne tol?re absolument pas, je sais que sur nombre de sites quelques intervenants ont tout les droits et les autres doivent plier&#33;
    comme je ne m&#39;inscrit pas encore ? l&#39;ordre les moutons de panurge je pr?f?re conserver ce qui me reste de personnalit? et prendre cong?,
    salut ? tous , et longue vie ? votre site
    baylyns
    Du calme Daniel, faut pas t&#39;enerver pour ?a et certainement pas quitter le forum.
    juin 2004
    Asnières
    1D MK III
    j&#39;irai bien faire un tour sur Megapixel, ?a doit d?chirer grave entre les Pro-20D, les Pro-10D, les Pro-300D et les autres qui doivent compter les points
Fuseau horaire GMT +1. Il est actuellement 11h15.
