Affichage des résultats 1 à 44 sur 44
Discussion: ED-SDK 2.7 En Delphi
    Nouvel utilisateur
    juillet 2015
    NIMES
    Canon EOS 1100D
    Rien de partiuclier :-) !
    Bonjour Xifit,
    je viens de tomber sur ce sujet qui m'interresse au plus haut point.
    Pourrais-tu me faire parvenir la DLL ?
    Merci d'avance.
    Gilles
    Nouvel utilisateur
    octobre 2015
    Denmark
    Canon EOS 1000D
    Skilled in Optics and Delphi programming
    Par défaut Avoiding the flickering and speed up things
    Next problem in PixelKs code from 09/04/2014 17h 14 is the annoying flickering and bad timing while in zooming in liveView.
    I did fix this by downloading the fast jpeg decoder unit jpegdec.pas from http://synopse.info/files/jpegdec.zip
    I did include jpegdec in the uses clause of the CanonCamera.pas
    Code:
    unit CanonCamera;
    interface
    uses
      Windows, Messages, Classes, Sysutils, Graphics, Jpeg,
      EDSDKApi, EDSDKType, EDSDKError, ExtCtrls,
      jpegdec;  //FabInSpace did add reference to jpegdec.pas on 11-10-2015
    And I did the following changes to the last part of the unit:
    Code:
    function TCanonCamera.DownloadLiveViewImage(Image : TImage) : Boolean;
    var
      MemStream: TMemoryStream;
      Stream : EdsStreamRef;
      evfImage : EdsEvfImageRef;
      JPG: TJPEGImage;
      ImageData : Pointer;
      ImageSize : EdsUInt32;
      BMP: TBitMap;  //Added 11-10-2015
    begin
      Result := False;
      stream   := nil;
      evfImage := nil;
      try
        Self.LastError := EdsCreateMemoryStream( 0, Stream );
        if Self.LastError <> EDS_ERR_OK then
          Exit;
        try
          Self.LastError := EdsCreateEvfImageRef( Stream, evfImage );
            Exit;
          Self.LastError := EdsDownloadEvfImage(Self.FRef , evfImage);
          begin
            EdsRelease(stream);
            Exit;
          end;
          Self.LastError := EdsGetPointer(Stream, ImageData);
          begin
            EdsRelease(evfImage);
            EdsRelease(stream);
            Exit;
          end;
          Self.LastError := EdsGetLength(Stream, ImageSize);
          begin
            EdsRelease(stream);
            Exit;
          end;
          MemStream := TMemoryStream.Create;
          try
            MemStream.WriteBuffer(ImageData^, ImageSize);
            MemStream.position := 0;
            {Old lines from before 11-10-2015
            JPG := TJPEGImage.Create; // The Stream is a JPEG Image
            try
              JPG.LoadFromStream(MemStream);
              //JPG.SaveToFile('LVSteam.jpg');
              if not Assigned(Image.Picture.Bitmap) then
                Image.Picture.Bitmap := TBitmap.Create;
              Image.Picture.Bitmap.Assign(JPG);
              Result := True;
            Finally
              JPG.Free;
            end;       }
            //New lines elliminating flickering
            with TMemoryStream.Create do
            try
              LoadFromstream(MemStream);
              BMP := JpegDecode(memory, Size);
              if BMP <> nil
              then
                try
                  Image.Picture.Bitmap := Bmp;
                finally
                  BMP.free;
                end;
            finally
              Free;
            end;
            //end of new lines from 11-10-2015
          finally
            MemStream.Free;
          end;
        finally
        end;
      finally
        EdsRelease(stream);
      end;
    end;
Fuseau horaire GMT +1. Il est actuellement 09h04.
