Discussion: erreur 06 sur 40D
    mai 2005
    Melun (77)
    R5 Mkar II et 7D Mark II
    Tout plein de trucs en L ou pas
    Le firmware 1.1.1 devrait régler ton problème (cf point 2 ci-desous)
    Firmware update Version 1.1.1 incorporates the following fixes and improvements.
    1.Fixes a malfunction that in rare occurrence causes a low battery indication to be displayed when using the EF 85mm F1.2L II USM lens. Depending on the battery check timing of the camera, the battery level displayed on the camera's LCD data panel may shows Battery will be exhausted soon or Battery must be recharged, even though the battery capacity is sufficient.
    2.Fixes a malfunction that in rare occurrence causes an Err 06 Self Cleaning Sensor malfunction to appear on the camera's LCD monitor and LCD data panel, even when the Self Cleaning Sensor Unit is operating normally. This message may appear depending on the timing of when the camera is switch to the ON position.
    3.Fixes a malfunction that prevents correct colors from being printed when direct printing. RAW images captured using the camera's custom Picture Styles (Emerald, etc.), which have been downloaded from Canon's Web site and registered under User Def. 2 or User Def. 3.
    4.Modifies the level of subject brightness that causes the AF-assist beam to fire when using an external Speedlite.
    5.Enables an external flash connected to the camera's synchro terminal to fire even when the camera's built-in flash is popped up.
    Version 1.1.1 firmware is for EOS 40D cameras with firmware up to Version 1.1.0. If the camera's firmware is already Version 1.1.1, it is not necessary to update the firmware.
    Nouvel utilisateur
    février 2010
    Châlons en Champagne
    EOS 40D
    18-55mm et 100mm macro USM
    Par défaut erreur 06 sur 40D
    Très bonne info!
    Je vérifie tout ça ce soir et je m'engage à vous tenir au courant du succés de la solution proposée.
    Merci d'avance à plus tard!
    mai 2005
    Melun (77)
    Et donc ... ?
    Nouvel utilisateur
    février 2010
    EOS 40D
    Talking erreur 06 sur 40D
    Oui désolé, j'ai mis un peu de temps à m'occuper de tout ça....:rolleyes:
    ça y est le firmware est mis à jour. Apparemment tout se passe bien. Je ne vois plus l'erreur 06 apparaître!!!!
    Merci à vous, et pourvu que ça dure!!!!:clap:
  1. Erreur 99
    Par spv_tj dans le forum Discussions Objectifs
    Dernier message: 31/03/2011, 09h14
  2. Help, bug erreur 99 sur Eos 30D
    Par gordonvet dans le forum Pannes, entretien et nettoyage
    Réponses: 20
    Dernier message: 08/12/2010, 01h04
  3. erreur 99 et erreur 05 !!
    Par lecorsair dans le forum Pannes, entretien et nettoyage
    Dernier message: 04/10/2008, 13h17
  4. eos 30D erreur 2
    Par freddonux dans le forum Discussions techniques
    Réponses: 18
    Dernier message: 20/08/2008, 08h40
  5. Erreur 99 ??
    Par newt dans le forum Discussions techniques
    Dernier message: 22/01/2008, 19h03
Fuseau horaire GMT +1. Il est actuellement 10h56.
