    Par défaut [Nouveau Firmware] 1DX
    Canon annonce un nouveau Firmware :
    LAKE SUCCESS, N.Y., October 17, 2012 – Canon U.S.A., Inc., a leader in digital imaging solutions, today announced a new firmware update in response to user requests which further enhances the capabilities of Canon’s flagship EOS-1D X Digital SLR camera. The EOS-1D X will now be capable of AF point illumination during AI Servo AF and cross-type AF for maximum apertures as small as f/8. The new firmware update is available now at no charge from the Canon U.S.A. website and can be downloaded by end users or through Canon Factory Service Centers.
    AF Point Illumination During AI Servo AF
    To support the needs of wedding, portrait, sports, wildlife, and theatrical performance photographers working in low light, the new firmware allows AF points in the EOS-1D X’s viewfinder to be illuminated in red when the shutter button is pressed halfway during AI Servo AF, for easy viewing of the selected point. This valuable feature will enhance the photographers’ ability to aim the camera accurately in low-light conditions, and when photographing dark subjects. To preserve exposure-metering accuracy, illumination is intermittent, not continuous. Three choices will be selectable from the menu system – Non-illuminated, Illuminated (Normal) and Illuminated (Brighter).
    Cross-Type AF Support at f/8
    The EOS-1D X is equipped with an innovative 61-point High Density Reticular AF System featuring up to 41 cross-type AF points, depending on the lens in use. The cross-type AF points recognize a wide variety of subject matter, making them highly desirable for maximum autofocus performance. Until now, cross-type AF on the EOS-1D X has been limited to EF lenses and lens/extender combinations with a maximum aperture of f/5.6 or larger. The new firmware allows cross-type autofocusing with the center AF point even when the maximum aperture of a Canon EF lens/extender combination becomes as small as f/8. Ideal for wildlife photographers and others who often use EF super-telephoto lenses with extenders, this new feature greatly expands the range of EF lens/extender combinations that support autofocus when used with the EOS-1D X.
    If AF point expansion is selected with an f/8 maximum aperture lens/extender combination, the four AF points surrounding the center point will act as AF Assist points. This option effectively expands the size of the AF detection area to enhance autofocus performance with subjects that are small in the frame and difficult to track, such as small animals and birds in flight. AF points above and below the center will be sensitive to vertical contrast, while points to the left and right will be sensitive to horizontal contrast.
    http://www.usa.canon.com/cusa/consum...OS1DX_firmware
    avril 2012
    Chàtel-St-Denis - Suisse
    D3 + Nissin 866 Mk II
    35-70 2.8 - 80-200 2.8
    Petit ajout nécessaire :
    The link currently doesn’t work, but should shortly.
    OK merci de l'info, en effet pour l'instant le lien est dead ..
    avril 2012
    Dommage qu'ils n'aient pas aussi modifier les points AF en one shot...
    Citation Envoyé par ICSTRA Voir le message
    C'est quand même moins utile quand même, car on entend que cela ne bouge pas sur le sujet ou pas dans le sens avant arrière, et qu'en général en basses lumière on a pas spécialement besoin qu'il s'illumine tout le temps.
    Cependant le faite d'utiliser le bouton AF On pour l'AF, je peux me permettre d'être en pseudo One Shot (mais en Ai Servo) je peux donc en bénéficier tout le temps
    Abonné Avatar de Kinggarden
    Territoire de Belfort
    Canon - Tamron
    Peut-être que Canon s'est rendu compte que l'absence du f/8 en AF était un frein à la vente du 1Dx face à son concurrent qui a implémenté cette fonction dès la mise en vente de son D4, et qui plus est, sur 11 points AF...Seuls les téléobjectifs ouvrant à f/2.8 en natif étaient utilisables jusqu'à présent avec doubleur sur le 1Dx avec l'absence du f/8, ce qui n'incitait pas nombre d'utilisateurs de 1D (et même de 1Ds) à faire le switch parce que possédant des grands blancs f/4, d'autant que en plus il y a la perte du crop factor de 1.3 avec le 1Dx.
    Mieux vaut tard que jamais, ce nouveau firmware qui corrige les erreurs commises par Canon au départ est le bienvenu, en souhaitant que comme Nikon il ne limite pas le f/8 au seul collimateur central comme c'était le cas sur les précédents boîtiers de la série 1.
    Le rétroéclairage de collimateur qui manquait également était pénalisant pour ceux qui opèrent en milieu sombre, ce qui était difficilement compréhensible face à la capacité de ce boîtier à s'accomoder d'une faible lumière. Ce nouveau firmware va en contenter également plus d'un qui déplorait ce manque.
    Je suis sûr que cette bonne nouvelle va booster les ventes.
    Pour l'instant le lien m'a l'air encore dead, je ne suis pas certain qu'il sera dispo aujourd'hui, peut être qu'ils se sont rendu compte d'un défaut ?!?
    Canon - Tamron
    J'avais entendu parler de 2013, peut-être faut-il ne pas être trop pressé, mais l'essentiel est d'avoir la confirmation que cela va se faire.
    Membre Avatar de jujernault
    paris
    5DMark III+grip-600exRT-2x430EX II-STE-2
    8-15L - 24-105 F4L - 85mm 1.2L - MPE-65-100mm F2,8L Macro - 70-200 F2,8L II -TC x2III
    c'est bien beau tout ses beau firmware pour le 1DX mais le 5D3?? et implémenté la possibilité d'avoir L AF a F8 signifie qu'il bride tout sur leur passage
    avril 2012
    Euh..tu peux développer?
    Canon - Tamron
    Citation Envoyé par jujernault Voir le message
    Pas compris ???
    Beaucoup de choses sont bridé par le firmware,ou disons plutôt par le marketing ...
    On l'a vu pour le 7d ... avec l’augmentation du buffer par le firmware ... Je bosse pour une boite qui fait la même chose ... différente gamme de produits, mais l’électronique est la même, seul le firmware bride les fonctions ...
    Membre Avatar de Ldo
    septembre 2010
    48°35'04''N 7°44'55''E
    5D III | 430 EX II
    50 | 24-105 | 70-200 | ex 2
    Et c'est frustrant quand on le sait, mais je ne vais pas m’énerver ici, c'est un sujet pour le 1Dx...
    Messieurs, pour info le nouveau firmware 1.1.1 est maintenant dispo au téléchargement :
    Canon U.S.A. : Consumer & Home Office : EOS-1D X
    Je viens de le télécharger, j'installe cela ce soir
    Quelques informations complémentaires sur cette maj (reçu par mail Canon CPS) :
    Nouvelles caractéristiques du firmware v1.1.1 pour Canon EOS-1D X :
    Autofocus opérationnel à f/8
    Illumination des collimateurs AF et des informations du viseur en AF Servo-Ai
    Corrections effectuées par le firmware v1.1.1 pour le Canon EOS-1D X :
    Correction d’un phénomène influant négativement sur la valeur de mesure du capteur d’exposition.
    Correction d’un phénomène provoquant l’apparition possible d’une Erreur 70 pendant une séquence de bracketing
    Correction d’un phénomène d’impossibilité de mise à jour normale du firmware des objectifs
    Corrections mineures du menu en langue arabe
    Pour info
    Membre Avatar de kinslayer
    juin 2007
    Pays Bas
    1DX MkII + 5D MkIV
    Canon: 16-35/2.8 III; 24-70/2.8 II; 100-400 II; 600/4 II | Sigma 14mm/1.8; 20mm/1.4
    Excellent. Limite jouissif même! On va enfin voir ses collimateurs dans la pénombre d'une salle de concert!
    Vivement demain soir que j'aille shooter
    Merci Canon (c'était quand même trop bête comme souci haha!)
    septembre 2010
    5D III | 430 EX II
    Arggglll, je peux aussi avoir ça sur mon 5D III m'sieur Canon, siouplé!
    Modérateur Avatar de Mnemmeth
    Graz, Autriche
    7D, 5D3 a peine deballe
    nan
    septembre 2010
    5D III | 430 EX II
    nan
    rabat joie!
    Certainement qu'ils feront cela aussi pour le 5D Mark III ... pas de raison que cela ne soit fait que sur le 1DX, surtout qu'en le faisant sur l'un via firmware on sait que cela est également faisable sur l'autre ... il peut par contre sortir bien plus tard, mais à mon avis ils risquent fort de le sortir assez rapidement ... le 5D Mark III étant dans une gamme suffisamment expert/pro pour justifier cela ...
    Wait and see donc ...
    septembre 2010
    5D III | 430 EX II
    Tes paroles me font trépigner comme une jeune jouvencelle!!!
    Faut parfois y croire ... pour ceux qui pensaient que le collimateur ne pouvait pas s'allumer sur le 1DX et qui savent maintenant cela possible sont certainement très satisfait ... ou vont bientôt l'être (dont moi )
    Donc on peut penser qu'ils feront cela pour le 5D Mark III étant donné que l'AF est identique et que cette problématique le concerne aussi ...
    Moralité : ont peut y croire ... et on espère ne pas se tromper
    septembre 2010
    5D III | 430 EX II
    Une question très con, mais je crois que c'est la plus con que j'ai jamais posé ici, en même temps ça doit être ma 5ème question;
    La voici, accrochez vous....
    Quelqu'un aurait il déjà essayait d'installer le firmware du 1Dx sur le 5D III, enfin celui d'un modèle sur un autre quoi!
    Sachant que je ne tenterais jamais cette experience!
    Punaise, j'ai presque honte de demander ça
    Luxembourg
    1DXMI, 5DMIV, 100D
    16-35 L III/ 24-70 L II/ 70-200 L II / 50 1.4 / 100 L
    Attends de voir le résultat de la mise à jour avant d'être satisfait
    Disant que si déjà il est capable d'allumer les collimateurs en basse lumière je serais forcément satisfait, car en effet ils sont sinon visible que pendant un très court laps de temps et pendant toute la durée du suivi il serait alors invisible ...
    Pas de raison que cela ne me satisfasse pas ...
    Pour le F8, je testerais avec TC1.4 + TC2 sur le 300mm voir s'il est capable de suivre ... même si cela n'équivaut pas à un 100-400 avec Tc1.4, car 2 TC collés donnent encore des images raisonnables mais l'AF était une cata sur le 1D Mark IV, il lui fallait quelques va et vient avant de fixer la visée ... ce serait uniquement pour voir ...
    avril 2012
    La plus con serait de demander si quelqu'un a essayé d'installer le firmware du 1100D sur le 1DX.....
    En général si l'apn n'est pas trop con avant d'appliquer un Firmware il serait sensé vérifier s'il est fait pour lui ... et refuser son installation avant de commencer
    Cependant cela peut être fait sur certaines cartes mères de PC, et les conséquences peuvent être le refus de redémarrer ... et en plus cela peut ne pas être réparé gratuitement en cas de mauvaise manipulation, donc personnellement je pense que cela bloquerait l'apn ou refuserait seulement l'installation, mais j'avoue que je ne ferais pas le test pour donner la réponse
    Pas si con, non, puisque la personne aurait une doc à lire bien plus "light"
    Bien que bien des personnes ne lisent déjà pas celle du 1100D ... pas taper je suis déjà dehors
    avril 2012
    On se demande d'ailleurs pourquoi on se retrouve avec 3 kgs de notices.....personne ne les lit et ca nuit à la planète....et le pire, c'est que quand tu veux revendre ton boitier, les mêmes vont demander une ristourne parce que tu as perdu la notice ..
    Luxembourg
    1DXMI, 5DMIV, 100D
    Apparement ce serait bien pire....les collimateurs clignoteraient en rouge !...ce qui serait très dérangeant. D'ailleurs la plupart disent désactiver l'option directement...Bon j'ai pas encore testé mais les retours sont inquiétants
    Citation Envoyé par Alexevana Voir le message
    Je te dirais ça ce soir ...
  32. #32
    C'est fait, en effet cela clignotte mais c'est pas très génant, à tester sur le terrain ...
  1. Nouveau firmware 40D / 50D
    Par Bob-74 dans le forum Canon
    Dernier message: 08/10/2008, 10h30
  2. Nouveau Firmware EOS 30D
    Par Scarb dans le forum Canon
    Dernier message: 03/11/2006, 09h57
  3. Nouveau firmware
    Par le-fugitif dans le forum Canon
    Dernier message: 26/03/2005, 11h34
  4. Nouveau firmware
    Par TransFXB dans le forum Canon
    Dernier message: 29/06/2004, 15h04
  5. Nouveau Firmware
    Par Cédric Girard dans le forum Canon
    Réponses: 33
    Dernier message: 21/06/2004, 20h45
Fuseau horaire GMT +1. Il est actuellement 22h14.
