Discussion: UFRaw gimp fichier raw eos 400d pour linux
05/10/2006, 08h33 #1Membre
- mars 2006
- St Armel Morbihan
- 62
- 2 765
- 7D, 40D, SX10IS
- 10x20Sig,18x200IS,28x75 2.8Tamr.,50 1.8,105Sig.,70-210 2.8Sig.,400 5.6L
Pour information et en avant premiere j'ai modifie UFraw et le plugins son GIMP pour decoder les fichier RAW des Canons EOS 400D
le tgz du code est sur le site suivant
http://velo-sport-de-rhuys.chez-alice.fr/ufraw-0.9.1.modif.tgz
Le site officiel de UFraw
http://ufraw.sourceforge.net
et la procedure d'installation :
recupere le fichier ufraw-0.9.1.modif.tgz
tar xzf ufraw-0.9.1.modif.tgz
cd ufraw-0.9.1.01
./configure
make
make install-user
plus d'explication sur l'installation sur le site UFRAW:
Now, you can download the UFRaw tarball ufraw-0.9.1.tar.gz, extract the files from it and enter the ufraw-0.9.1 directory:
cd ufraw-0.9.1.01
Next, you should run the configuration script:
./configure
You will get a long output and at the end there will be a summary that should look approximately like:
configure: ====================== summary =====================
configure: build gimp plug-in: yes
configure: hidden directories support (GTK>=2.6): yes
configure: EXIF support using libexif: no
configure: EXIF support using exiv2: no
configure: JPEG support: yes
configure: TIFF support: yes
configure: TIFF deflate (lossless compression) support: yes
There are also UFRaw specific flags for configure:
--disable-gimp - disable build of the gimp plug-in
--enable-extras - build extra (dcraw, nikon-curve) executables
--with-libexif - use libexif to read raw EXIF data
--with-exiv2 - use exiv2 to read raw EXIF data
--with-prefix=PREFIX - use also PREFIX as an input prefix for the build
--with-dosprefix=PREFIX - PREFIX in the the prefix in dos format (needed only in windows)
Next, you should build UFRaw by typing the command:
make
For installing the UFRaw Gimp plug-in, you have two options. You can install it only for the current user, which does not require root privileges, but only the current user will see the plug-in
make install-user
or you can make a system wide installation (requires root privileges)
make install
This will also install the stand-alone tools ufraw, ufraw-batch and some related files (man page, icon and desktop definitions).
05/10/2006, 09h08 #2Membre
- janvier 2006
- Rennes
- 45
- 2 613
- EOS
- Kenko EF 10-300 1.8 IS USM
Bonne initiative, au cas où tu peux soumettre ta modif à l'auteur de façon à l'inclure dans la distribution officielle (si pas déjà fait
05/10/2006, 09h23 #3Membre
- juin 2006
- toulouse
- 60
- 30
- canon eos 33
- Canon
Au fait, j'ai découvert ce tutorial très bien fait (assez récent?) sur UFraw, qui répond à pas mal de questions que je me posais. Et en plus c'est en français!
http://gimp-fr.org/document/document_22/
Bonne lecture,
RB
18/10/2006, 22h53 #4Membre
- octobre 2006
- Belgique
- 47
- 2
- eos 400D
avant d'aller plus loin, pouvez-vous me dire comment faire pour monter mon eos 400d sur linux?
Merci d'avance pour votre aide.
19/10/2006, 00h51 #5Membre
- janvier 2006
- Rennes
- 45
- 2 613
- EOS
Salut nauw,
tu ne peux pas le monter en tant que stockage de masse.
Pour récupérer tes photos, tu peux utiliser gtkam ou digikam sous kde, f-spot ou gthum sous gnome.
Seul gthumb ne permet pas d'importer les .cr2 .
19/10/2006, 13h19 #6Membre
- septembre 2006
- Loire Atlantique
- 54
- 674
- 7D
- 18 à 400 mm
C'est juste sous Nux ou c'est compatible crosoft ??
19/10/2006, 13h38 #7
19/10/2006, 16h59 #8
19/10/2006, 19h50 #9Membre
- octobre 2006
- Belgique
- 47
- 2
- eos 400D
Super!!!
En fait l'erreur venait des droits d'accès sur le port, en root, pas de problème ça se monte.
C'est vraiment un super appareil... en plus il fonctionne bien sous GNU-Linux, que demande le peuple!!!?
Merci pour les infos.
20/10/2006, 08h44 #10Membre
- mars 2006
- St Armel Morbihan
- 62
- 2 765
- 7D, 40D, SX10IS
cinepaint 400D
Si ca interesse quelqu'un, j'ai aussi modifie un fichier dans les sources de cinepaint
pour convertir des raw du 400D
L'avantage de cinepaint sur gimp est qu'il travaille en 16 bits par couleur
cinepaint est un evolution de gimp ....
luc
20/10/2006, 13h51 #11Membre
- septembre 2006
- Loire Atlantique
- 54
- 674
- 7D
- 18 à 400 mm
Mais sinon sous crosoft vous auriez pas la même chose ........
Pour le 400D biensur
Dernière modification par Blue ; 20/10/2006 à 13h54.
20/10/2006, 14h00 #12Membre
- janvier 2006
- Rennes
- 45
- 2 613
- EOS
La plupart des logiciels de traitement des fichiers raw se sont mis au goût du jour et prennent en charge les fichiers raw du 400D ... dpp, lightroom, bibble, camera raw, et j'en passe certainement..
Light Zone pour Linux
Par kagou dans le forum Les Logiciels photoRéponses: 18Dernier message: 13/04/2008, 07h54 -
Dcraw et Ufraw pour 40d
Par luc56 dans le forum Les Logiciels photoRéponses: 0Dernier message: 07/10/2007, 16h53 -
DCRAW/UFRAW pour Gutsy
Par kagou dans le forum Les Logiciels photoRéponses: 1Dernier message: 06/09/2007, 21h50 -
Numération des fichier - 400D
Par pomodoro dans le forum Discussions techniquesRéponses: 6Dernier message: 02/04/2007, 12h48 -
400D : Pas de Fichier RAW ?!
Par labestyle dans le forum Discussions techniquesRéponses: 12Dernier message: 19/02/2007, 03h48
promis je vais lire les titres :fear(1):
