    Membre Avatar de emst
    Métropole Lilloise
    1D Mark III - 350 D
    EF 16-35 2.8L + EF 24-70 2.8L + EF 50 1.8 II + EF 28-200 3.5-5.6 + EFS 18-55
    Tout d'abord voici un lien :
    http://www.photozone.de/lens-test-faq
    Va faire un tour sur ce site, tu pourras te faire un comparatif des 2 zooms à ouverture identique. Tu verras que le f4 IS, hormis qu'il n'ouvre pas à 2,8 obtient des résultats bien meilleurs que le f2,8 IS.
    Je ne trouve pas cela spécialement logique parce plus tu prends un zoom de grande ouverture, plus tu payes, plus tu es en droit d'exiger de la qualité mais de part ce qui est incrit les f2,8 IS ne sont pas sans problèmes : Voici quelques extraits
    Problème de différence de qualité entre 2 zooms différents :
    "Two sample of this lens has been tested. The first sample performed quite poor and the 2nd sample did outperform its quality figures but not without problems. This 2nd sample has been tested once more after a calibration by the Canon service."
    Conclusion :
    "The Canon EF 70-200mm f/2.8 USM IS is a very good lens but not a stellar one. The resolution characteristic is excellent at 70mm and 135mm but at 200mm it disappoints - more so regarding its price tag. The results are still very good here (just at f/2.8) but when putting things into perspective (e.g. vs the superb EF 70-200mm f/4 USM L IS) the delivered quality is not overly impressive. Based on the performance at 200mm the potential with tele converters seems "limited". Lateral chromatic aberrations (CAs) are relatively well controlled but, again, inferior to the in-house competition (inc. its predecessor). Distortions are nothing to worry about as is vignetting. The build quality of the lens is superb and the IS as well as the very fast AF makes it a joy to use. If only it was better at 200mm ... "
    Vis à vis de tout ce qui précède, je pencherais plutôt pour le f4 IS.
    Salutations
    Emmanuel
    Métropole Lilloise
    1D Mark III - 350 D
    ... Et voici la conclusion pour le f4 IS :
    "Every now and then EOS, the goddess of mercy, seems to speak to the Canon lens designers and this time they listened carefully. The Canon EF 70-200mm f/4 USM L IS may well be the very best tele zoom on the market today - it is certainly the best Canon zoom lens tested locally to date. The lens was capable to deliver a near-flawless performance is all categories. The resolution figures are stunning regardless of the setting. Distortions, vignetting and CAs are nothing to worry about. The build quality is excellent with the new sealing as a another highlight. On top of that the lens now features a image stabilizer with an efficiency equivalent to 4 f-stops (at cost of shutter speed). The only heartbreaking drawback for some is the price tag which increased significantly to a whopping grand - price/performance-wise this is still very sound though. "
    Membre Avatar de sk8
    octobre 2005
    EOS 40D/ 1D Mark III
    Canon : 17-40L | 100 Macro 2.8 | 70-200 f/2.8 IS USM | 400 L 5.6
    Citation Envoyé par emst Voir le message
    La bonne blague ! tu n'es pas obligé de croire tout ce qui est écrit...
    Luxembourg
    1DXMI, 5DMIV, 100D
    16-35 L III/ 24-70 L II/ 70-200 L II / 50 1.4 / 100 L
    Citation Envoyé par marwag Voir le message
    Effectivement, j'ai possede les 2 objectifs et je peux vous garantir que le f/4 ne pique pas plus que le f/2,8, bien au contraire. Par contre, il est evident que d'un exemplaire a l'autre il peut y avoir des differences.
  1. 70-200mm f4 IS ou f2.8
    Par stewart dans le forum Discussions Objectifs
    Réponses: 30
    Dernier message: 19/02/2008, 07h16
  2. EF 70-200mm f/2.8 L IS - Probleme de MAP
    Par Alexevana dans le forum Discussions Objectifs
    Réponses: 35
    Dernier message: 22/01/2008, 21h05
  3. Canon 28-200mm ou Sigma 18-200mm que me conseillez vous
    Par fr92fab dans le forum Discussions Objectifs
    Dernier message: 20/06/2007, 22h15
  4. EF 200mm f/2.8L II USM
    Par Ritchie dans le forum Discussions Objectifs
    Dernier message: 22/04/2005, 09h05
  5. 200mm f/2,8 L USM Vs 70-200mm f/2,8 (sigma)
    Par Jibs dans le forum Discussions Objectifs
    Dernier message: 06/02/2005, 22h05
Fuseau horaire GMT +1. Il est actuellement 18h34.
