Page 3 sur 3 PremièrePremière 123
Affichage des résultats 91 à 109 sur 109
  1. #91
    Membre Avatar de DigitalP
    janvier 2005
    Au pied de St Victoire (AIX-13)
    + de 21Mpixels
    Nombreux!
    Une piste pour la lenteur avec l'outil de retouche local. Certains ont remarqué cette lenteur
    avec des cartes vidéo NVidia Ge Force, l'astuce consiste à désactiver les options d'accélération de la carte graphique, et ça semble (mais c'est pas une généralité) beaucoup mieux marcher.
    Allez sur le forum utiiser lightroom pour plus d'infos.
    RH
  2. #92
    1DIII & 40D / 580EXII
    17-55 f2.8 IS / 17-85 f4-5.6 IS / 24-70L f2.8 / 70-200L f2.8 IS
    J'ai effectivement trouvé ceci (source ici):
    I have finally fixed my slow performance issues with LR2! Today I did a bit of playing around with different performance settings. I'm using LR2 on a HP Pavillion 6258se Laptop. It has an 80GB Hard Drive, 2GB of Ram and the processor is a 1.8 GHz AMD Turion ™ 64 X2 Dual-Core. I had Windows Vista installed months ago but I downgraded back to XP due to Vista issues. First I opened the windows task manager so I could monitor the performance of Windows while using LR2. I noticed when using the develop tasks the performance stayed around 50%. When I used the retouch brush tools the performance still stayed around 50% but the brush tools were still slow. The more I brushed on the image the slower the brush refresh became. This told me that there must be a video performance issue and not necessarily a processor problem.
    Here's how I fixed the problem.
    1. I right clicked on the desktop and clicked NVidia Display/Laptop
    Dispay.
    2. Clicked on the Performance and Quality Settings
    3. Under Active profile Click Global Driver Settings.
    4. Under Global driver Setting click in the dropdown view advanced settings.
    Changed the following settings:
    Images setting = High Performance
    Force mipmaps = None
    Trilinear Optimization = Off
    Anisotropic mip filter optimization = Off
    Anisotropic sample optimization = Off
    Triple Buffer = Off
    Without even restarting LR2, the brush tools worked with no lag or delay no matter how much I brushed on the image! They were just as fast as using the sliders in the develop module!
    I hope this works other Nvidia users having similar issues!!
    Mark
    et une autre info sur les forums d'Adobe ici qui indique qu'une piste serai désactiver le "nView Desktop Manger" :
    I use the "nView Desktop Manager". It was fine for Lightroom 1.4 but causes real performance problems with Lightroom 2.0, in particular when loading the Develop Module.
    Select the Develop Module then close Lightroom. The time taken between starting Lightroom and for it to become responsive with nView enabled was around 25 seconds, with nView disabled it takes around 7 seconds.
    I had similar performance issues whenever I used the Spot Removal Tool or Adjustment Brush, and in particular the first time loading the Development Module within a session. Basically the tools in the Develop Module are now responsive whereas before it took 3 to 5 seconds each time I clicked on one of them.
    To disable "nView Desktop Manger" for Lightroom only;
    Right click the desktop > nView Properties
    OR Control Panel > NVIDIA nView Desktop Manger
    then;
    Applications > Add... > Browse... > C:\Program Files\Adobe\Adobe Photoshop Lightroom 2\Lightroom.exe > OK > lightroom (Application) > Disable... > CLEAR Enable nView Desktop Manager for this application and/or class > OK > OK
    Bon, moi j'ai aussi une nvidia mais je n'ai pas encore remarque de lenteur particulière ; je ferai quelques tests prochainement. Si toutefois vous avez des retours sur ces conseils, je suis sûr que beaucoup seront contents de les connaître :-)
  3. #93
    janvier 2005
    + de 21Mpixels
    Nombreux!
    Pour préciser je l'ai fait sur ma vieille NVidia 6700 ou 6800 (me rapelle plus) là je suis sur le protable, et j'ai gagné en vitesse de l'ordre de 2 à 2,5 fois! Adopté me concernant, mais mon PC ne sert qu'à LR.
    RH
  4. #94
    Membre Avatar de sk8
    octobre 2005
    EOS 40D/ 1D Mark III
    Canon : 17-40L | 100 Macro 2.8 | 70-200 f/2.8 IS USM | 400 L 5.6
    Merci à vous pour ces infos...je testerai prochainement (quand j'aurais un peu de temps).
  5. #95
    aucun
    aucun
    A svoir qu'on peut modifier ces paramètres application par application...
    Moi j'ai créé un profil pour Lightroom (pas testé encore)
  6. #96
    août 2005
    Loire Atlantique
    Faire de belle photo
    il y a une version 2.1 RC, voir lien ci dessous pour plus de détails, en attendant la version finale !
    http://labs.adobe.com/wiki/index.php/Lightroom_2.1
  7. #97
    Liège, Belgique
    EOS 80D
    EF 17-40 F4 L USM + EFS 17-55 + EFS 15-85 + AF 28-75 + EF 50 1.4 USM + EF 70-300 IS U
    Quelqu'un a essayé les nouveaux profils d'étalonnage de l'appareil dispo sur adobe labs ?
    Pour ma part ils poussent un peu trop le rouge mais se rapproche déjà plus des couleurs voulues que les couleurs de bases (ACR 3.6 et 4.4).
  8. #98
    Abonné Avatar de briceos
    As tu l'adresse de ces profils d'étalonnage. Je n'ai pas trouvé ! Merci !
  9. #99
    Peut-être veut-il parler de ceci ou, plus précisément, ceci...
  10. #100
    Liège, Belgique
    EOS 80D
    Oui c'est bien ça dont je parle.
    Qu'en pensez-vous ?
    Vous ne trouviez pas que les couleurs étaient mieux gérées sous DPP (logique dans le sens ou c'est estampilé canon, ils savent comment déamtricer leur fichier) et que ces profils LR rattrapent un peu le coup côté couleur sans devoir systématiquement rechercher un traitement à chaque photo ?
  11. #101
    Membre Avatar de caouito
    St Victoret (13)
    Eos numerique
    Citation Envoyé par chrisbati Voir le message
    Qu'en pensez-vous ?
    J'ai comparé les fichiers DPP et LR avec le profil "standard" : Les couleurs sont identiques. Maintenant, je ne l'ai peut-etre pas fait sur un panel d photo assez large...
  12. #102
    octobre 2005
    Citation Envoyé par MacDo Voir le message
    Merci , j'ai testé, c'est beaucoup mieux ! par contre, je n'ai plus, quand j'utilise le pinceau, le rond avec le masque rouge de la modification une fois que j'ai appliqué la correction : comment on fait ? j'ai rien trouvé à ce sujet
  13. #103
    Montpellier
    R6 et R7
    Citation Envoyé par marwag Voir le message
    touche "o"
  14. #104
    octobre 2005
    Citation Envoyé par digitalreflexe Voir le message
    touche "o"
    Merci, j'essaye ce soir !
  15. #105
    octobre 2005
    touche "o"
    Le masque rouge apparait bien mais je n'ai pas le bouton gris qui normalement doit rester sur la photo...
  16. #106
    Membre Avatar de OlivierC
    10D/5D/1DIV/Hasselblad H5D-60
    touche "h"
    (comme "hide")
    et "shift o" pour changer la couleur en autre chose que du rouge
  17. #107
    octobre 2005
    Citation Envoyé par OlivierC Voir le message
    touche "h"
    (comme "hide")
    ça marche, encore merci !
  18. #108
    aucun
    aucun
    Citation Envoyé par caouito Voir le message
    Tout à fait, c'est pareil, avec les param à 0.
    Par contre, perso dans DPP je poussais un peu la saturation, et là, ça devient impossible à simuler dans LR.
    Pas grave ceci dit, je n'ai jamais été fana de DPP non plus.
  19. #109
    Abonné Avatar de lbuisson
    OISE-60
    Sony A9 / CANON G15 et AE-1
    Non pas encore il ne s'agit que de la 2,1 RC
  1. Finale top 14...
    Par chriscb dans le forum [Galeries membres]
    Dernier message: 05/07/2008, 12h53
  2. Lightroom sortie version 1.4.1
    Par chiwindi dans le forum Lightroom
    Dernier message: 12/04/2008, 01h26
  3. Sortie de DxO version 4
    Par Fred08 dans le forum DXO
    Réponses: 46
    Dernier message: 23/10/2006, 18h41
  4. Lightroom beta version
    Par URBANQUEST dans le forum Discussions techniques
    Réponses: 17
    Dernier message: 21/07/2006, 12h22
  5. PSElements version 1 et version actuelle
    Par placitric dans le forum Les Logiciels photo
    Dernier message: 04/01/2006, 22h58
Fuseau horaire GMT +1. Il est actuellement 12h10.
