Discussion: Style d'image "Neutre" ?
23/07/2018, 14h25 #1Membre
- octobre 2009
- 55
- 62
- 321
- EOS 50D.7DII,6D
- 28-105 100 Macro 24-70 70-200 100-300
Voici quelques informations concernant le style fidèle vs style neutre trouvées sur un site CANON:
(Désolé en anglais).
Faithful Picture Style
When looking at the Picture Styles available in EOS cameras, the parameters of both
Neutral and Faithful look identical, however there is a difference.
While both will produce flat, muted images, if you are shooting products that have a
defined colour (for example the red of an Italian sports car) then by shooting with
the Faithful Picture Style and using lighting that has a colour temperature of 5200K,
the colours in your images will be colourimetrically accurate.
If your client needs you to match the colours of their product, this is therefore the best Picture Style to use.
If you use Faithful Picture Style in lighting that is not 5200K you will find the
colours in your images can shift slightly and look unnatural.
In this case, you should use Neutral Picture Style instead.
Question : comment "supprimer", les "détails" dans les "proprétés" des images ? MERCI
Par clo1467 dans le forum Discussions généralesRéponses: 16Dernier message: 27/10/2014, 21h47 -
[Débat pour les courageux] Comment sortir du "style conventionnel" ?
Par Cunione dans le forum Discussions généralesRéponses: 24Dernier message: 28/01/2013, 22h19 -
40D - Faux contact bouton "style d'image"
Par Abzalon dans le forum Pannes, entretien et nettoyageRéponses: 4Dernier message: 28/02/2010, 18h56 -
Vos paramétres "style d'image" sur 40D
Par tigrou78 dans le forum Discussions techniquesRéponses: 12Dernier message: 02/04/2008, 23h34 -
Fond "gris neutre"
Par breizheau dans le forum Discussions techniquesRéponses: 5Dernier message: 04/03/2005, 11h49
