Toujours sur le site canadien, DPP 3.11.26 vient de faire son apparition.
Mais quand on clique sur le lien pour le téléchargement, on tombe sur une erreur...
Donc encore un peu de patience.
Changes for Digital Photo Professional 3.11.26 Updater for Windows;
- Now supports the following new lenses.
EF24mm F2.8 IS USM, EF28mm F2.8 IS USM, EF24-70mm F2.8L II USM, EF500mm F4L IS II USM, EF600mm F4L IS II USM
- Supports images taken with EOS 5D Mark III, EOS-1D X.
- The digital lens optimizer function has been added.
- The multiple image composition and HDR tools have been added.
- Fixed a phenomenon that occurred when processing RAW images, the original image characteristics could not be obtained.
- Fixes a malfunction that occurs when using the quick check tool to check a large volume of images.
