    Membre Avatar de rico7578
    Monde
    Canon 5D mkIII
    du 17 au 600mm
    Ca a l'air kiff kiff niveau bruit entre 450D et 500D en JPEG, par contre un poil moins bon en RAW d'après le test de dpreview :
    Canon EOS 500D / Digital Rebel T1i Review: 15. Photographic tests (Noise): Digital Photography Review
    Je cite pour la comparaison en JPEG :
    "Looking at the EOS 500D compared to the EOS 450D at ISO 1600 it's good to see that the extra pixels haven't had a significant impact on the higher ISO capabilities of the sensor. Having said that the 500D is not significantly better than its predecessor in the noise department either although admittedly you can still keep shooting with the new model when the light gets too dark for the 450D's ISO 1600."
    Par contre il est un poil moins bon que le 450D en RAW, je cite :
    "With noise reduction reduced to a minimum the 500D's more tightly packed sensor produces visible and measurably larger amounts of both luminance and chroma noise than the Nikon and, surprisingly, also the EOS 450D. In fact, while the Nikon arguably produces the cleanest high ISO RAW image in this test, the 450D follows very closely in its tailwind. When looking at these RAW crops and corresponding JPEG samples above it becomes clear that on the pixel-dense 500D sensor Canon has not been able to keep RAW noise levels down to 450D levels but does a pretty good job in limiting the impact of this on its JPEG output by using improved noise reduction algorithms. "
    Mais si tu imprimes à la même taille la différence doit être négligeable avec le 450D, le 500D te permettra simplement d'avoir en plus accès aux sensibilités de 3200-6400-12800 ISO... mais avec un résultat pas top
    Dernière modification par rico7578 ; 01/11/2010 à 18h17.
  1. Quel remplaçant pour mon 450D ?
    Par Eowyn68 dans le forum Choix d'un Boîtier
    Réponses: 47
    Dernier message: 02/06/2013, 13h25
  2. Passage du 450D au 5D
    Par gaettan dans le forum Discussions techniques
    Dernier message: 21/10/2010, 20h41
Fuseau horaire GMT +1. Il est actuellement 03h38.
