Affichage des résultats 1 à 45 sur 234
Discussion: Achat : 5D Mk II ou le nouveau 7D...?
06/09/2009, 01h37 #1Membre
- août 2007
- 1 000
- 1D MKII, 5D MKII Gripé A/H1N1
- 17-40/4, 28-300/3.5-5.6 IS, 85/1.2 II, 200/2.8 II, 500/4 IS, TC 1.4 et 2 II
Lit jusqu'à la fin... ^^
Are smaller pixels somehow worse? Not necessarily. Just because the diffraction limit has been reached with large pixels does not mean the final photo will be any worse than if there were instead smaller pixels and the limit was surpassed; both scenarios still have the same total resolution (although one will produce a larger file). Even though the resolution is the same, the camera with the smaller pixels will render the photo with fewer artifacts (such as color moiré and aliasing). Smaller pixels also provide the flexibility of having better resolution with larger apertures, in situations where the depth of field can be more shallow.
achat nouveau reflex après 350 D
Par KIP dans le forum Choix d'un BoîtierRéponses: 14Dernier message: 31/08/2009, 15h08 -
Problème Boitier 20D > achat nouveau boitier
Par cougnews dans le forum Discussions techniquesRéponses: 5Dernier message: 06/05/2009, 18h59 -
conseil achat: grand angle Tokina, flash Sigma ou nouveau boitier canon 40D?
Par midiweb dans le forum EOS 40DRéponses: 3Dernier message: 06/03/2009, 10h50 -
avec le nouveau 5D, un nouveau caillou ???
Par stesty dans le forum Rumeurs, potins, supputations...Réponses: 21Dernier message: 09/09/2008, 20h13 -
Nouvel achat, Nouveau venu!
Par Nighthawk dans le forum Présentations & règlementsRéponses: 22Dernier message: 15/05/2008, 08h26
